Question about D-Link AirPlus DI-524 Wireless Router
Router seems to be hooked up as it should be. no problem with the main computer. when i install the reciever thig in my laptop nothing happens, the laptop says it found this but i cannot get enternet what can i do??
  • D-Link Master
  • 19,396 Answers
Try first unplugging and restarting the router.
If on startup the WAN/Internet light on router is off, then call the Internet Service Provider.
If the router is connected to the Internet, then connect to the router using an Ethernet cable and check router setting.
You will need to access control panel entering in Internet Explorer top bar router IP. The IP will be something like 192.168.0.1.
The default IP is listed on the manual. If you do not have the manual, or if default IP does not work, then yo can find the IP accessing the command prompt (type CMD in the run box that you find on start menu).
In command prompt type Ipconfig/all . The router IP will be listed as default gateway.
In control panel check security settings, ensure that there is connection, and try changing the wireless encryption key.
Posted on Sep 05, 2009
The router is not showing up anymore when i look for networks on my laptop so i cant get online on my laptop anymore but my main computer (which the router is hooked up to) works fine
well the reason the computer that is hooked up finds it is because it is connected to it and there is nothing that would make it not find it what you need to do is press the reset button on the router then everything will be fine and if you changed the password the password will be the one that came with it which is usally on the bottom or you can change it with your main pc i could talk you through the settings but there is no point when the reset button will do the same as i would i hope this has helped and i look forward to hearing how you got on
Jan 15, 2011 | Computers & Internet
Running install disc, says does not support operating system
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 03, 2010 | NetGear WGR614 Wireless Router
My F5D7234 is not working w/ Windows 7. Watsup?
Is your modem connected to the main computer or the router ?
If the main computer is connected to the computer then you will need to connect the modem to the router .
Check the connections.
check the settings on the router.
I hoe the following link will help you.
Nov 09, 2009 | Belkin F5D7234-4 Router
No Wireless/ wi-fi
did you install the modem driver aswell? the modem and WiFi wireless is a mixed unit, as need both drivers to funktion.
/Teis
Jan 03, 2009 | ASUS Z83V Notebook
Moved network
You should be able to switch the two, however, if this requires a network to be set up in order to run both computers through the same router, I recommend having someone do this for you.
Aug 22, 2008 | Acer Aspire 3680 Laptop
Connection lost everytime phones on
The phone and the router are using the same wireless channel and/or wireless band. You can access the router console by inputting it's IP address, usually 192.168.1.1 by default, in the address bar. Once there you can change the channel your wireless signal uses to be something different you phone uses.
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Signals
Do you have a wireless adapter installed on your win 2000 computer?
Jul 01, 2008 | Linksys Wireless-G WRT54G Router
Wireless networking
well, as it says, you only need a wifi usb adapater to recieve signal. if you do have a wireless router, then you can use the wifi usb to recieve signal from the wireless router.
Feb 18, 2008 | Office Equipment & Supplies
A problem concerd with my hp 520 laptop
see it is bcoz of the bios setup it is not detecting you can do one thig just enter in your bios setting and there is option for sata mode change it native maode disable and save the bios cmos setting come out of it and run the setup it will detect the hdd
Sep 28, 2007 | Computers & Internet
D-Link AirPlus DI-524 Wireless Router Logo
16 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
