Haven't used my system for awhile, bought a new battery and plugged in AC..all I get is the following buttons turning on and off...no voice..no nothing.. Disarm-System Status-Chime Doors-Windows and Sensor Light goes on and off about every 3 seconds
My Optima XM6 fuse blew,I powered the system down,replaced the fuse and battery when I connect it...
(More)
My Optima XM6 fuse blew,I powered the system down,replaced the fuse and battery when I connect it back up the alarm sounds and the code number will not stop it.How do I remedy this?Thanks.
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code...
(More)
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code for the mother, it says invalid or cannot be used. Does it matter if I duplicate digits??? example code: 2311
we have had a gemini security system but have not installed it. Then, the baby in the house pressed...
(More)
we have had a gemini security system but have not installed it. Then, the baby in the house pressed on, but no one had a code. it has been going on repedely.
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I...
(More)
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I can't figure out how to open the control panel. Thanks a lot for the answer, Mike
