Question about Nokia 3555 Cellular Phone
I have a nokia 3555c cuts of an restarts
I have a nokia 3555c and if you're in the eq stettings and press the end button it restarts help??
Who do i print a pdf using a usb
Insert USB into port. Press print button. Select USB from drop down menu.
Jul 29, 2014 | Toshiba E-Studio 3555C Multifunction Color...
I cannot open it coz i forgot the lock code i set
Pres three switch call +end+manu +Power on
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory
stetting.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 17, 2011 | Nokia X6 16GB Cell Phone
I have nokia Nokia N79 i buy used Mobile And i dont know what is old Security Code is please help me in it
Just follow the steps
Make a backup of contacts in your another sim.
Switch-off your phone.
1. Press and hold three keys at a time;
You will use three finger for pres three keys .dial switch 3 key(from key pad) star( *) and pres the on switch.
Green dial key,
* Star key,
No. 3 key
Then Power on/off to switch on the phone.
.Soon an formatting text, will appear ,then stop pressing those switch, remember. 2. After a few minutes when the Full
phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
Jan 16, 2011 | Nokia N79 Cellular Phone
Need help on setting custom EQ for my JVC KD R506 in car music system. m not able to find the settings. also any idea how to increase the bass effect from the speakers. can i connect a subwoofer without an...
Set your equalizer to you a V shape or U shape pattern, bass effect can only attain by adding a powered subwoofer, (amplifier and subwoofer). subwoofer without an amplifier doesn't sound good, your system doesn't have enough power to drive your subwoofer.
Jun 23, 2010 | Car Audio & Video
Auto eq wont turn off
You have to press the STORE button. Also, this will only save to the preset you're on and has no effect on other presets. So if you're on preset 1 and you disable EQ then press STORE you've only turned it off for that preset. #2, 3, etc. will still be enabled.
After you press STORE will show you something like this:
STORE: ROCK VENUE
Replacing
U1 DJ Setup
PRESS STORE TO ADVANCE
Rotate the DATA whell to select the program to be replaced and press STORE. The existing program (the one that had EQ turned on) will be replaced with the new program (the EQ turned off). If, for example, you do this to preset 1, now every time you dial to 1 you'll have the same, no EQ setting.
Jan 23, 2010 | DBX Driverack-Pa Eq/Speaker Control System...
My Nokia 3555c mini display is mirrored.
u can try *#5511# if not become ok then u need go to hardware tecnication for solving it. may be ur display diod has unpluged or damaged.
Jul 29, 2009 | Nokia 7610
My high end cuts out
eq is give problem check or replace
May 05, 2009 | AudioControl Three.1 4-Band Car Equalizer
Nokia 5800 restarts automatically
try factory reset
go to menu>applications>file manager>backup>options>backup now
this step is intended for content backup, if you don't care to lose your personal info skip it
backup done?
1.first way to apply factory settings: go to menu>settings>phone>phone mgmt.>factory settings>yes
2.another way to apply factory settings:(three finger salute)
now switch off your 5800
while it's off press and hold these three buttons at the same time send(green button) + end(the red button) + camera button(found on the side)
while you're pressing these 3 buttons switch on your phone and hold on to the 3 keys until the hands video is infront of you
the phone then asks for date and so...
tell me if the problem persists and try to clarify it further ahead
i own a 5800 and may be i can be of help
May 02, 2009 | Nokia 5800 XpressMusic Smartphone
What buttons do i press to get my phone on nokia n73
Hold the "end" button down to see if device will boot up. If the "end" button is not the correct button for booting the device on, look to the top of your N73 where you might notice a button with a circle. If there is a button on the top of your Nokia N73 similar to what I described this will be your power on button, in which you will need to press down on the button until handset powers on.
Hope this helps! Thanks.
Apr 02, 2009 | Nokia N73 Cellular Phone
Mackee PPM808M 1200 How to set the equalizer
Each channel strip has its own 3 band EQ with knobs that effect the hi, mid, and low.
The mid is centered at 2.5kHz and gives you 12dB of boost or cut in either direction, the high gives you 15dB of boost or cut from 12kHz and up, while the low gives you 15dB of boost or cut at 80kHz and below. At their mid positions these knobs are flat (no cut or boost).
The PPM808M also has two 9 band graphic EQs in the Master Output Section on the front panel, Monitor EQ and Main EQ. These two EQs are the last thing in the chain before the signal leaves the mixer on either of these line outs (monitor line out, or mixer line out).
The 'Monitor EQ' effects output to the monitor speakers on stage (and power amplifier if the 'Power Amp Routing' switch is pushed in).
The 'Main EQ' effects the signal to the main speakers (or the mixer line out).
Each of these 'Master Output' EQs has a Rumble Reduction button which when pressed in engages a low-cut filter which rolls off frequencies below 75Hz and is designed to prevent 'stage rumble' from things like footsteps on the stage being picked up by stage mics. These filters are separate from the graphic EQs and the Main Rumble Reduction switch effects only mono channels 1-6 (not stereo channels 7&8). It also has no effect on the EFX to MAIN or the TAPE IN. The Monitor Rumble Reduction switch however does effect the EFX to MON signal.
Dec 31, 2007 | Audio Players & Recorders
Nokia 3555 Cellular Phone Logo
216 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
