Question about Garden
My John Deere 6.5 HP S.P. lawn mower suddenly stopped running. I discovered the Kill switch was broken and bypassed it with a jumper. I replaced the spark plug also, but it still won't start. Any suggestion?
  • Tedd Smith
    Tedd Smith Sep 07, 2009
    actually, it is the interlock switch and the plug sparks with the switch disconnected. A small amount of gas put in the cylinder gets it to fire, but it will not run. Seems to be a fuel problem now.
  • 143 Answers
When you bypassed the switch what did you connect the wire to.
This is an earth wire, keep it loose and see if the engine will start, if it will,
touch the wire against the engine and it will stop. Stephen
Posted on Sep 06, 2009
Testimonial: "Helpful, but motor still won't start"
I have a 2010 John Deere 777 Riding Lawn Mower that stop cutting all of a sudden as I was mowing this morning. Do you have any idea why?
Cutting or running? Big difference..if stopped cutting most likely your belts came off the pulley or broke...have to take a look..Stopped running need more info...good luck..
Aug 25, 2015 | John Deere Garden
180 john deere riding lawn mower
Your deck belt slipping. It need adjusted or replaced
Aug 11, 2014 | John Deere Garden
John deere lawn tractor not getting spark on left side?
check wire maybe broken inside they do wear out
Jul 26, 2014 | John Deere Garden
John deere L20 tractor mower will not start. it wont even turnover. i think it has something to do with the pto kill switch
There probably several kill switched, on the PTO and another under the seat. For diagnostic purposes only the switches can be jumped with a wire to see which switch is bad. Once it is located remove it and replace it with a new one.
May 21, 2014 | Garden
How to test a solenoid for a John Deere 115 Lawn Tractor with 42" deck?
http://www.greenpartstore.com/assets/images/instructions/2012/am138497_installation_instructions.pdf
John Deere Starter Solenoid Kit AM138497
First make sure the negative battery cable is making good contact on the frame or what ever part of the mower it is connected to. Make sure both battery cables are clean and not corroded and are tight. Then try to start the mower. If it works, fine. If not then you will bypass the solenoid and see if the starter turns the engine. To bypass the solenoid take a car jumper cable and connect one clamp to the terminal on the solenoid that goes to the battery ( see the diagrams in the links above) Turn the ignition switch to the on position. Take the other end of the same color of the jumper cable (say you'll use the red clamps) and touch the clamp to the other large terminal on the solenoid, which goes to the starter. If the starter turns the engine, then you know the starter is good and that the solenoid is bad. If the starter does not turn the engine then the starter is bad. make sure you DO NOT touch the jumper cable to the starter case or any other ground.
May 18, 2014 | John Deere Garden
Lx 176 John Deere stopped running suddenly. Found this wire disconnected where does it go?
Probably the kill switch wire that would normally attach to the throttle linkage plate to complete a ground circuit for the ignition coil. If you can follow it and see if it ends up at the ignition/kill switch
Apr 21, 2013 | Garden
I have a 14 HP Kawasaki engine on my John Deere lawn mower (LX176). I have no spark.I'm guessing coil but unsure of how to test it. I get readings through the windings with an OHM meter but I don't know...
All the "safety" engine-kill "features" on this mower will ground the ignition system, stopping the engine and causing a no-spark condition. Check the seat switch, the brake switch. Also, the circuit board will cause the problem you have if it gets rained on, (the mower hood does not protect it); point is do not let the mower get rained on (or washed) unless you protect the PC board, which is right behind the ignition switch. Mine dried out and worked again but only after liberal spraying with (plastic-safe) electronic parts cleaner. You are right the manual would help, it's like $76 but it's in depth. Good luck, and PLEASE tell us what the solution was! -Tom
Helpful Deere lx176, lx178, hood hinge tip: If the hood hinge is broken on yours like on most, Deere has a GREAT repair kit that's only $10. They really priced it at cost or less to correct a defect they are aware of.
Jul 14, 2010 | kawasaki Full Suspension Mountain Bike Men
I need to run the mower deck belt on my john deere L130 lawn mower and would like to know if there are any diagrams for that
I have to replace my broken belt on my L110 John Deere mower. I have the new belt in my hand...
May 16, 2010 | Garden
John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
533 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
