Question about Bosch Dishwashers
Dishwasher without power
I have a Bosch s10r1b dishwasher. Suddenly during its cycle it shut down. It appears to have no power at all now.
What could be the problem?
Sincerely
  • thomas259 Sep 06, 2009
    I already checked the electrical source and its ok. Problem must be in the dishwasher. Is there a fuse inside?
  • 5,603 Answers
Check the electrical source. Possibly the breaker blew or he plug went bad.
The electrical load varies drastically during a cycle due to heater, motor, etc. If the breaker blew, ONLY reset it ONCE to try as there may have been a serious problem within the dishwasher. ALSO if the unit shares the power with another device that could cause the problem.
Posted on Sep 05, 2009
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Aggravating loss of power
It sounds like a heat sensor is being tripped (or shorted)
Jul 09, 2008 | Bosch 23 in. SHU303 Built-in Dishwasher
Bosch Dishwasher Model shu9915uc
ok sir! maybe you have defective motor thats why your unit is in abnormal power.
Oct 23, 2007 | Bosch SHU9915UC Dishwasher
Manual for a Bosch S10R1B Dishwasher
Here it is: http://elektrotanya.com/?q=showresult&megnev=bosch%20&megnev2=S10R1B%20&kategoria=&kat2=all
Just press the blue arrow and, after the page opens, "Get Manual".
Apr 12, 2010 | Audiovox Bosch 718 World Cellular Phone
Opened door on cycle, will not continue cycle after closing door
The most common problem for a dishwasher to not restart after the door being closed is a failed door latch interlock switch. Adjusting / repairing it is not too difficult.
Of course this assumes that the Dishwasher power circuit from the circuit breaker remains powered up.
Post back here if you are looking for more details.
Good Luck!
Apr 16, 2009 | Bosch 24 in. SMU40 Built-in Dishwasher
Dishwasher quit during cycle.
Need a little more info.. anyway.. open dr will shut off dw...close dr.. push power button until power on... lights on, but nothing happen.. try holding down drain and one of wash cycle.. repeat holding drain w/other buttons until you hear drain pump running.. make sure you hold both buttons for a few seconds.. if your drain pump works.. then, you might have a problem w/your wash motor or something is stuck in the impeller area.
Jan 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher switched itself off during cycle - no power now
It is possible that some of the pips have been washed down into the drain pump and jammed the impellor, follow the drain hose back to the pump underneath of the dishwasher make sure the d/washer is switched off at the power supply before you attempt this, if you have reasonable mechanical skill you should be able to remove front of pump to clean it.
Oct 09, 2008 | Bosch Dishwashers
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU3036UC not filling with water
u need more info first what happens when u shut the door and start a cycle
Nov 05, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
488 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
