Question about Aprilaire 400 Humidifier
Constant Red Light on Control Panel Circuit Board
Humidifier now does not work. The reset does not work. However there is now a constant red light illuminated on the circuit board within the humidistat housing.
Note - a cpmplete new HVAC system was recently installed.
  • OneMackGuy Dec 08, 2007
    Model is an Aprilaire 400.
    Problem Solver:
  • 13 Answers
The red light under the cover of the humidistat is fault light. This light typically indicates that there is an issue with your connection at the two wiring terminals labeled ODT on the humidistat. I would recommend checking to confirm that there is something currently connected to the two terminals. As a side note these two terminals can not be jumped out with a jumper, and must utilize either the outdoor temperature sensor (part 8052) or the manual mode resistor (part 4336).
Posted on Apr 23, 2010
2005 Aprilaire 700 humidifier. Replaced a non-working circuit board. Now, the humidifier works fine when the furnace is running. It starts and stops as it should based on humidistat setting. Problem: ...
It sounds like it is just miswired. The low voltage wiring off the humidistat should be on W and C on the circ. board at the furnace. If you have it on R and C then it will power it constantly regardless if the heat is running or not. W is only energized on a call for heat which is typically when you want that type of humidifier to run
Feb 02, 2013 | Aprilaire Humidifiers
I have just completed installing a Honeywell HE220A humidifier to a Carrier Weathermaker 8000vs that was installed in 2003. My problem is that all the identified circuits in previous posts on the circuit...
I believe that Carrier has a 24 volt setup for humidifier but am not sure. On the circuit board I think there is a terminal (HUM). If there is this terminal connect 1 wire to this and 1 wire to C terminal.
If not,pretty sure there is a 120 volt EAC terminal. This would only kick on when blower is on. If you have to use this you would have to install transformer to the EAC connections
Jan 28, 2011 | Honeywell HE220A1019 Whole House...
We noticed the humidity went down to 30% and I adjusted the rate to increase Now our Aprilaire 400 says to change the filter. I did that, and it still says to change the filter. The furnace runs fine....
If your humidifier is equipped with a Digital Humidifier Control with Water
Panel change indicator, after replacing the Water Panel, turn the control
knob to the "Test/Reset" position until the "Humidifier On" light blinks to
reset its timer. (Blower must be operating and HVAC calling for heat.) Be sure
to turn the control knob back to it's original setting. If the "Humidifier On"
light continues to blink, your humidifier is in Test mode. DO NOT LEAVE THE
CONTROL IN TEST MODE OR HUMIDIFIER WILL NOT OPERATE.
Jan 27, 2011 | Aprilaire 400 Humidifier
I replaced the water panel on our aprilaire 600 humidifier. I adjusted the thermostat to call for heat to test it. When the dial (non-digital control panel for the humidifier) is turned to test/reset,...
Thank you for contacting us with regards to your model 600 Humidifier. The Change Water Panel indicator should flash when the control knob is set to the Test/Reset mode. The flashing indicates that the timer has been successfully reset. However, the humidifier should operate for the first 60 seconds of Test mode as long as your furnace is running. If your humidifier does not turn on, contact your installer. The humidifier may require service.
We appreciate the opportunity to be of assistance.
Sincerely,
Brett Phillips
Technical Support
Research Products Corporation
Nov 01, 2010 | Aprilaire 600 Humidifier
Humidifier filled with water, but red light is on
If you overfill it, the red light goes on. just dump a little out and it should go green. Worked with my crane duck humidifier. Hope it helps
Feb 01, 2010 | Crane Humidifiers
Humidifier control: red light is on. getting 24
the red light is lit because either you didnt install the manual mode resistor or your not using a out door thermostat but you have to hook somthing to the two terminals just to the right of the HH terminals
Dec 23, 2009 | Aprilaire 600 Humidifier
The red light is always on in my humidifier control panel. When I set it to test, I hear nothing clicking. No water runs into my humidifier. The unit (model 600) is about 6 years old.
if your using an outdoor thermostat then it may not be connected properly or the manual mode resistor wires are touching. these are connected on the humidistat just to the right of the H H terminals
Dec 12, 2009 | Aprilaire 600 Humidifier
Aprilaire 400 Humidifier Logo
1,097 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
1STHVACMAN
Doug
Level 1 Expert
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
