Question about Porter Cable 7336 6 Inch Variable Speed Random Orbit Sander Only
The sander is chatterin g on the oak wood and only barely stops if I apply a whole lot of pressure. I don't want sanding marks so how can I fix it?
  • Porter Cable Master
  • 5,603 Answers
You may be applying too much pressure. Also it is my experience with this type sander that one has to use the side of the pad. If you try to use the whole flat pad they chatter. For flat sanding I use a "Jitterbug" type sander. What you have is for coarser work I SUSPECT than what you are trying to do. The quarter sheet type would probably be better for you.
Posted on Sep 05, 2009
Dewalt belt sander stops sanding when pressure applied
I would suggest giving our Service Center so we can get your unit looked at. DEWALT com
Mar 15, 2015 | Dewalt Tools & Hardware - Others
Tip
How To Re-Wax a Wood Deck for a Trotter Treadmill
Following are instructions on how to re-wax a wood deck for a Trotter treadmill and a list of materials needed for this procedure
Materials Needed for Re-Wax
  • 1 lb. of Trotter deck wax
  • Clothes iron (never to be used on clothing again)
  • Belt sander with 120 grit sanding belt
  • Vibrating sander with 250 and 400 grit paper
Pre-Existing condition: If your wood Trotter treadmill deck is worn down through the first ply, it cannot be re-waxed.
  1. Using a belt sander and 120-grit belt, gently sand in the same direction as the grain the glazed layer off the top of the deck until you have reached porous wood. If, while sanding, the first layer of ply has been sanded off, the deck can no longer be re-waxed
  2. Using a vibrating sander with 250-grit paper, sand the entire top surface of the deck until it is smooth and soft.
  3. After sanding with the 250-grit paper, continue sanding with 400-grit paper until completely smooth.
  4. Heat the clothes iron to its maximum temperature. Put a handful of Trotter deck wax on the center surface of the deck and place the preheated iron on top of it until the wax melts.
  5. Work the wax into the deck surface by pushing the melted wax across the deck with the iron. Add more wax as needed until the entire top surface of the deck is impregnated with wax.
  6. Apply just enough wax until the wood is saturated with wax.
Do NOT leave wax pooling on the surface of the deck.
How To Re Wax Wood Trotter Treadmill Deck
on Mar 11, 2015 | Exercise & Fitness
What causes my belt sander to leave black goo on the wood? I keep replacing the sand belt, I do not push the sander into the wood.
Maybe you are burning the wood. If the wood is hard (like oak or maple) and the grit is fine (like 100 or higher) then this can only be avoided by NEVER running it still in one place. Keep the sander moving quickly over the surface. In fact, you should start the sander BEFORE you touch it to the wood, and when you do touch the wood you should be landing it like a little airplane on the runway. As long as you keep the sander oriented with the grain you can move it forward and back as well as side to side. Just keep moving until you lift it off of the wood - this also helps keep the surface flatter. Good luck.
Jul 30, 2012 | Skil 3 in. x 18 in. Belt Sander - 7500
Hello I have a compressor and my electric orbital sander has finally gone legs up. My question is if I get an air sander primarily for sanding wood is a straight line the best sort to get or are the...
I work in a wood working shop and we use orbitals on everything. You still will still sand with nice even strokes with the grain. It leaves a great finish. They are nice, light, and easy to use! They do use a lot of air though, so make sure your air compressor can handle the one you buy. If you compressor is constantly running you might have to take breaks so you do not burn it up. enjoy!
Apr 11, 2011 | Sander Viking Air Tools Dual Piston...
I am sanding down oak boards that i have laminated together for a bar top. no matter what grade of belt i use or how careful i am it is leaving lots of ridges in the wood. never had this happen before
Belt sanders are not good for finish sanding because they will leave ridges, but they are great for removing lots of wood fast and getting you roughed in. Use the belt sande to get your work fairly level then switch to a palm sander to get it smoothed out.
Feb 09, 2011 | Makita 9404 4'' x 24'' Belt Sander
Porter Cable random Orbital Sander (Quicksand) Model 333, Double insulated When sanding, it stops and starts, it sounds as thogh it is stuck and then gets going for a short while
Hi, Sanders are prone to getting lots and lots of dust inside the unit. The cooling fan makes this problem inevitable. The only way to fix this is to take it apart and and blast it with a pressurized air tool. Hopefully this will bring back some life to your sander. The effectiveness of this procedure is dependent on how well you can remove all of the dust. hope this helps.
Nov 16, 2010 | Porter Cable 332K Quicksand Random Orbit...
Clarke plate sander vs drum for a floor that only needs
drum sander leaves chatter marks you must plate these out. belt sander is the best way to go, however it will take longer to just plate than to drum and plate. for light sanding i would start with a 60 grit on the drum, then 80, then 100. plate with 100 screen till chatter free, then final with 150 screen. this is if you intend to go to raw wood.
May 13, 2010 | Clarke Floor Sander Floor Sander Orbital...
Dewalt hand sander not working properly when you apply to wood it stops turning
could be stuck bearing or loose screw on the drive. give me the model number and I will try and find you a breakdown for it.
Sep 22, 2009 | Dewalt Tools & Hardware - Others
I have the porter cable 7424 buffer/polisher. My problem is when you apply any pressure, even the weight of only the buffer on the car it stops spinning. You have to hold it up slightly lifting the we
The armiture has a winding problem, common in a lot of power tools. Replacing the armiture is not cost affective unless your time put into it is worth it, sorry. I recomend the Dewalt veriable speed, nice professional buffer!
May 07, 2009 | Porter Cable 7336 6 Inch Variable Speed...
Hook and loop pad
Try the amazon, here: Amazon com Makita hoop loop. Wish you best of luck. Cheers
Fred
Mar 25, 2009 | Makita BO5010 5" Random Orbit Sander
Porter Cable 7336 6 Inch Variable Speed Random Orbit Sander Only Logo
105 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim London
Jim London
Ed Mac
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
