I have a Model 24AF46 TV that displays a bright horizontal line across the middle of the screen. Below the line, the abbreviated/vertically compressed picture occurs in a trapezoidal area. The screen is otherwise blank above the horizontal line and below the two-inch wide trapezoidal area. 1)What is the matter with the TV? 2)If it needs to be repaired, what do you estimate the cost to be?
    Brigadier General:
  • 4,090 Answers
Repairs to the control board vary depending on where you live USA EU AU. But guessing I would say between 2 and 300. If you explain as you have here to any repair group they can give you a close estimate.
It is always cheaper to transport it to be repaired than having a callout so you can save some $$ in that exercise.
Posted on Sep 05, 2009
Toshiba 36HF12 TV has a horizontal bright line across no picture
Failure of vertical scan output circuit. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Nov 11, 2015 | Toshiba Televison & Video
Sony model KDL32L5000 has a black horizontal line across the display. above the line picture is fine, below the line display is distorted... any ideas?
Faulty vertical deflection section. check the yoke vertical winding. maybe its cure from service mode. search online how to apply service mode of you tv brand, model and board chassis number.
Aug 17, 2014 | Televison & Video
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
Philips Magnavox 20MS3442/17 Green Line
If this is a tube type or crt type. Your vertical circuit has a problem. Could be the vertical IC loose connection on its board. Or the vertical ic itself is faulty. If just resoldering or refluxing of its pins doesn't help check some minor cmponent within vertical circuit. Or the vertical ic is defective already.
If your not inclined on electronics never do the repair itself, nasty voltages might caught you.
May 11, 2009 | Philips Magnavox 27MS343S 27" TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Picture/image problem
Bad solder connection in the horizontal pincussion circuit.have someone resolder.God luck.4tune
Jan 09, 2008 | Televison & Video
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
POP and noothiing
yes it can still be fixed! the pop sound you've heard maybe came from a blown capacitor in the vertical deflection circuits. this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 10, 2007 | RCA E13309 13-Inch Diagonal XL-100 Color...
Tv not working
Mar 08, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
