All modern gas dryers use a hot surface igniton system(very old dryers had pilots). There could be a problem with the igniter,gas valve, ect. If you remove the bottom cover panel or inspection cap you can check to see if the hot surface igniter starts to glow when dryer is intially started. Just because the igniter does not glow does not mean that the igniter is the problem. There are two gas valves that work in conjunction with the ignition system as a safety(one could be defective). Also make sure that the gas connector at the back of the dryer is not restricted(kinked) and the gas line valve did not get shut off some how.
Roper model. 5 years old. The timer clicks and works. The door switch works. I connected the 2 wires...
(More)
Roper model. 5 years old. The timer clicks and works. The door switch works. I connected the 2 wires from the thermal fuse to bypass it. It did not start. For a week or so, I could smell something comming from the dryer room. Looked at the belt and it seemed fine, motor does move freely. Is there another fuse somewhere to test. AND if I need to take off the barrel to get to the motor, book says turn clockwise, but I didnt have success. Could you explain how to hold whatever needs held to get it off. So, is how can i check the other fuse, where is it? and Do I need to take the barrel off and how?
Roper Model #RED4000SW0--no heat...I have the back of the dryer off, but don't see where a fuse is...
(More)
Roper Model #RED4000SW0--no heat...I have the back of the dryer off, but don't see where a fuse is located...HELP ME!!
our dryer does not heat up at all to dry our clothes it operates as expected except for that one...
(More)
our dryer does not heat up at all to dry our clothes it operates as expected except for that one problem
the dryer seems to be running fine but it's like the pilot light isn't on adn i don't know where to...
(More)
THE DRYER SEEMS TO BE RUNNING FINE BUT IT'S LIKE THE PILOT LIGHT ISN'T ON ADN I DON'T KNOW WHERE TO FINE IT ON THIS DRYER
my roper dryer rgs748bkq2 is not putting out any heat. there seems to be no other problem with it....
(More)
MY ROPER DRYER RGS748BKQ2 IS NOT PUTTING OUT ANY HEAT. THERE SEEMS TO BE NO OTHER PROBLEM WITH IT. DOES IT HAVE A PILOT LIGHT AND IF SO WHERE IS IT LOCATED. JUST BLOWING COOL AIR.
