Question about Husqvarna Designer I
Pulley cant get it off
  • deborahcha May 11, 2010
    what is the model of the machine? Is this a sewing machine? Further info is needed.
I have a Husqvarna Designer 1. The motor pulley is worn down and I need to replace it. I cannot find a dealer on line that sells them. Where can I find a motor pulley for my machine. RC
Posted on Jan 01, 2013
  • love2sew382
    love2sew382 Jan 01, 2013
    I have a sewing machine not a large piece of equipment Ms. Computer. LOL...
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Closing issue since no additional info provided.
Posted on Feb 13, 2010
I have a Kenmore 158-3500 sewing machine and cannot get the side plate off near the hand wheel I have removed the clutch wheel but the hand wheel and belt seem to keep the plate from coming off.
The machine has two belts, one from the motor to a transfer pulley and the second from that pulley to the handwheel. You have to loosen the motor mount (one large screw/bolt) to release tension on the transfer pulley which in turn releases tension on the handweel belt. You will have to take the belts off the transfer pulley to slide the handwheel off (assuming you have already removed knob in the center of the handwheel)
Don't forget to lubricate the shaft of the transfer pulley while you have the end cover off. If this runs dry you will have a problem.
Good luck
Bob
Jan 22, 2017 | Kenmore Sewing Machines
Kenmore sewing machine keeps squeaking how to stop it?
Hello Shirlene, If your Kenmore machine has two drive belts, a belt from the motor to an idler pulley and a belt from the idler pulley to the main shaft. I have found that the idler pulley needs some Teflon grease on the idler pulley shaft. On my machine, the squeak would go away for a while if I oiled this idler pulley shaft. But it was short lived. Only grease on the idler pulley shaft would silence the squeak.
Oct 23, 2015 | Kenmore Sewing Machines
Pulley spins on motor drive shaft
There should be a set screw on the pulley that tightens the pulley to the drive shaft. It needs tightening.
Mar 07, 2015 | Sewing Machines
Change drive belt
Setting the belt tension on the 707-708-717 machines with the old rubber "Continental" belts:
1. Make sure that the hand-wheel spins freely on the main-shaft bushing stub when the release knob is loosened.
2. Assuming that you are using the original 441mm "Continental" rubber v-belts, the setting is made by means of loosening a 5mm Allen socket cap screw at the base of the step pulley support.
_____________
NOTE: The hand-wheel, stepped pulley, and motor pulley v-grooves must be clean. This is to say, that they cannot have any particulate or threads wrapped around the grooves.
4. The pulley will be automatically pre-tensioned to a 7 o'clock position by means of a spring to maintain the stepped pulley position. By pulling the belt toward this 7 o'clock position, the pulley tension can be adjusted and then tightened by means of the fixing screw.
_____________
5. It is important to know that both the upper and lower belt tensions can be independently adjusted so as to allow the hand-wheel to spin freely for bobbin winding without having the hand-wheel drive the machine. This is done by adjusting the step pulley support + or - radially, near the 7 o'clock position.
If the hand-wheel drives the machine with the upper belt loosened, then either the belt is too tight or the hand-wheel bushing and main-shaft stub need cleaning and lubrication.
Note: Lubrication was once the standard factory procedure with a class 68 oil, but experience dictates a dry lubrication with graphite. Silicone lubes are not recommended.
6. Do not over-tighten the 5mm Allen fixing screw as the 5mm threaded frame boss can be broken off.
Adjusting with the original Polyurethane v-belts on models 807-801-810-817-811 machines:
1. Follow the same procedure as mentioned but allow the step pulley's positioning spring provide the belt tension. Nothing more is required here.
NOTE: Sometimes these belts and pulleys get oily thus allowing much slippage. A simple cleaning of the belts and pulleys with mineral spirits can solve this problem.
After-market belts:
NOTE: One can find after market belts that serves to drive these machines but not without some problems as they are usually wider belts and don't fit the pulleys well. In this case some adjustment will be necessary.
SewTechnical Home
Mar 28, 2014 | Bernina Sewing Machines
How to tighten belt on Juki ddl-5550
the adjustment is done by getting under the table and loosening the bolts on the big pully. Then hopefully it will drop some or might need to help it with a rubber hammer. Then retighten the bolts.
Jan 14, 2013 | Juki Sewing Machines
Hi, I just acquired a consew 206RB machine but not the manual. It starts very fast so,I'd like to know if it has a speed control. Thanks
I slowed mine down by replacing the pulley on the head with a larger pulley that I bought at the local hardware store. All of the internal parts slowed down by the same amount so after 20 years it still works fine.
I used a 6 inch pulley (about $10.00) with a 1/2 inch center hole. Finding the right size of drive belt was the hardest part of the whole operation.
There are only two screws that hold that pulley on. One of them is a set screw very near the small center hole that stops the pulley from spinning on the drive shaft.
I'm using a 206RB-1 for house furniture
Nov 17, 2010 | Consew 206RB
Necchi Model 535 FA - Replaced drive belt, after running machine for approximately 5 minutes, machine locks down with motor running, motor pully burns plastic belt into.
The motor is running.That is confirmed that motor is fine.But the wires from motor has to be checked.the motor connections are getting short and this is causing the plastic belt to burn.Check the motor as well as its connection.
thanks.
Jun 05, 2010 | Necchi Sewing Machines
The machine's needle doesn't move
see user manuals check all wire and conect. if engine is running and turns
the pulley and the pin is still trying to tighten the pulley nut on pulley.if belt pulleys or manually by turning the needle does not move then may exist mechanical failure....
Dec 24, 2009 | Singer 1507
Tacsew lu-563 sewing machine
Generally going to have to be addressing the drive motor, either substituting a lower speed clutch motor for the existing one, ie if you have 3000 rpm motor, then going to a 1725 rpm motor. Alternatively, selling the clutch motor and buying a servo motor instead, which should be available with a variable maximum speed control. The Sewquiet 4000 can select different speed ranges with the flick of a switch. If you already have a servo motor and it does not have a variable max speed, then switching the drive pulley on the servo motor to a smaller size should help
A more convoluted solution would be building a support under the table for a layshaft with different pulley sizes so that the motor could drive one pulley and then a smaller pulley on the shaft would drive the sewing machine. Not a bolt on solution but pretty cheap to do if you are good at fabricating.
Apr 07, 2008 | Tacsew Sewing Machines
Sewing Machines Logo
29 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
