Question about Whirlpool Duet GHW9150P Front Load Washer
WE just installed both the duet washer and dryer. The dryer starts up just find but the washer will not turn on. Checked the outlet and it is working..so there seems to be no power getting to the machine. Any suggestions?
  • 6,784 Answers
Hi, check the following trouble spots below. you will find the issue in one or, all the areas stated.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch/door latch
The washing machine may not function if the lid switch or door latch mechanism is defective. The switch is usually located near the door. Replace if found defective.
**If you are getting power to the washer and, step 1 and 2 check out ok, replace the timer control or control Board and start switch as well.(You can test the continuity or, resistance level of the Lid/door switch with a multimeter(ohm).
Posted on Sep 05, 2009
Duet Washer Won't Start; Outlet Fine
How old are they & where did you get them from?
Jan 30, 2014 | Whirlpool Duet GHW9150P Front Load Washer
No power to my whirpool duet steam washer is there fuses in it
No I don't think there is any fuse and problem most likely main board problem
Dec 09, 2013 | Whirlpool Duet Steam WFW9700V Front Load...
The dryer won't start, when I push the start button is just beeps. I checked the door and it's shut and nothing is in the way. It was working a few hours ago. We had a bump in the power earlier today...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My dryer is making my clothes soaking wet every time I put clothes in. How do I turn the warer off on the steam mode (I guess)
Same problem here....I have had my brand new Whirlpool Duet Steam front load washer for a whole 4 days... It has worked perfectly until now. I checked on the clothes because it seemed like they just kept going and going... they were soaking wet!! When I took the clothes out the dryer had a huge puddle of water in it..Can anyone offer any help?
Sep 30, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
My Whirlpool Duet Washer won't turn on. I switched the cords going into the outlet and the dryer works fine on both sides. Thanks.
Do you have any lights on the consel at all? If not you have either a bad user interface (which is the control pannel with the lights) or your have a bad central control unit( Control board).
Aug 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Need to reset a whirlpool duet washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT Front Load Washer- won't start
remove the plug of the machine from the power outlet and plug it after 10minutes and then check .
if the frontpannel screen shows any error codes or any lights flashing check out this link
http://www.applianceaid.com/frigidaire_frontload_washer5.html
also check out this link for more help
http://www.applianceaid.com/frigidaire_frontload_washer.html
thanks.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer dryer error code 'check outlet pipe'
the outer drum could have dropped ]it might be a shock gone or top spring] close ire bye
Oct 11, 2007 | Hotpoint Aquarius WD640 Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
67 people viewed this question
Dan Webster
Dan Webster
Sal De
