Question about Kenmore Washing Machines
Need repair manual to replace bearings stackable washer
  • 15,935 Answers
Check behind the control panel for your service manual. One is included with every appliance sold.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
Fridgidaire stackable washer dryer model: fleb8200dso will not fill with water
You will need to replace the water inlet valve. Here is the part to order.
Here is the service manual to help you with the repair.
Nov 26, 2012 | Washing Machines
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
I have a Maytag stackable washer dryer Model #MDE2400AYW A repairman has diagnosed a problem with a rim that goes around the front of the dryer barrel which rotates the dryer. The bearings have worn...
If you need the whole housing we have it available for about $45. But usually you just need the bushings $35 part # AP4045830 . If you enter your model # at www.appliancehelponline.com diagrams will come up on the left hand side you will see the housing and the bushings that support the front of the drum. There are also videos of repairing similar bearing types. All parts come with installation instructionsand are ready to ship. It is an easy inexpensive fix.
Jan 10, 2011 | Whirlpool LTE6234D Top Load Stacked...
The tub has a crack stackable washer machine.told
If you bought it brand new in 6/08, try calling Frigidaire yourself and see if they will replace the tub for you. It can't hurt to try.
Jan 10, 2010 | Frigidaire Washing Machines
Sears stackable one peice unit. washer top load on bottom and dryer front load on top. The proble is when the washer is in the spin cycle it make a teriable load noise. Like it is grinding becase of a...
Your brearings are possibly worn, when the machine is off open the door and grab a hold of the drum (metal part on the inside) lift this drum if your bearings are worn it will have some play within its housing, i.e. it will move before the inner tub does and mannually rotate it you should here the bearings rumble if so also. they wear over time. you may be able to get them replaced but check prices first as it may be cheaper to get a new one bearing changes can be labour intensive.
Sep 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable washer unit will not spin. Keeps breaking belts.
either the motor is locking up or there is a bearing going out
Apr 17, 2009 | Washing Machines
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Kenmore Model 94812301 Stackable Washer/Dryer
try adjusting the feet on the bottom. apart from that the bearings may need replacing.
Sep 01, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Frigidaire stackable washer-dryer
I would check the manual.
Mar 22, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
