Question about KitchenAid K45SS Classic Stand Mixer
Ksm90wh mixer leaks oil was told it needs oil
Kitchenaid ksm90wh mixer leaks oil was told it needs oil change i want to know how to do it
    President:
  • 1,723 Answers
There is no oil to change on your mixer. What you are seeing is a bit of oil that is coming from the grease in the gear system. It separates from heat and leaks out after you get it warm from heavy use. There is nothing to worry about and there is really nothing you can do but wipe it off and clean it up. Everything will be fine, there is no maintenance required
Posted on Sep 05, 2009
Kitchenaid leaking oil
Remove the chrome drip ring that covers the outer planetary, clean it out, wipe as much oil away as possible, put the drip ring back on and carry on using it. Eventually you will need to completely dismantle the gearbox and clean out & change the grease. It's not the sort of job to look forward to. The old grease slowly breaks down over time and the oil is separating out from the grease solids. It is special food grade grease so completely harmless.
Feb 08, 2014 | KitchenAid 32685 Mixer
Leaking oil around head
These mixers are filled with grease at the manufacturer, and the heat may have broken down the grease a bit and looking like oil. Without seeing the problem, or knowing the exact location of the leak, I would say that a gasket or "O" ring has failed. Contact Kitchenaid for a gasket/seal rebuild kit. If it is new(er), It may be covered under warranty.
Dec 22, 2010 | KitchenAid KSM103 Professional 5 Series...
Who repairs Kitchenaid mixers(Model KSM90WH) in my area? I live near Wayzata ,mn.(55391)
I repair Kitchenaid mixers. I'm in lakeville, and you can email me at fixmymixer@aol.com. Thanks, Chris
Jan 04, 2010 | Food Mixers
My Kitchenaid Artisan Mixer is leaking oil or grease
Your kitchenaid mixer is meant to leak a tiny amount of oil around the rim of the planetary gear on the front of the machine. This is just a means of lubrication. If however you are getting alot of oil coming out of the sides of the unit, the transmission gasket may be worn or broken if this is the case it will have to be replaced. part number for the gasket is 4162324. If your getting alot of oil from the center of the unit this could indicate worn or broken seals. there are 4 located inside the unit, and would need to be dismantled in order to replace. part number for all four is 3180163. If you are leaking alot of oil or grease continued use of the mixer might cause it damage. Hope this helps
Thanks
Nov 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
The mixer leaks oil around the shaft. Is this a user repairable problem? How do I find service centers?
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
If you still feel as though the mixer is in need of service, you may locate Kitchenaid certified repair centers through the following link: http://caservice.kitchenaid.com/
Jul 10, 2009 | KitchenAid K45SS Classic Stand Mixer
Leaking oil
Jun 27, 2009 | KitchenAid Classic Stand Mixer
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
Oil leaked from housing
my ultra power ksm90gr 300 watt mixer leaked oil when in the upright position overnight. whats that all about?
Nov 10, 2008 | KitchenAid K5SS Heavy Duty Commercial...
K45SS leaks lubricant
Exploded parts views for all mixers are available at www.kithchenaid.com. Click "Customer Care" in the upper right hand corner of the main page, and then select "Locate Manuals and Guides." You will need to enter the unit's model number exactly as it appears on the bottom of the mixer. It will be listed on a white sticker.
Nov 03, 2008 | Food Mixers
KitchenAid K45SS Classic Stand Mixer Logo
160 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
