How old is the cartridge? It may have a built-in chip that activates this message, and it may be time to replace it. The reason the fax still works may be because a small reserve is left for just that purpose in case you don't get back to your computer in time.
Check and make sure you drivers are up to date. You may need to un-install the printer software and remove the printer in the control panel. Then reboot the computer,install the software(check and see if there is updated software if so download it).Then install the software and usually gives you instructions on when to connect the printer and drivers should be installed by software. Also make sure that when you use the print screen that you have the default printer selected and that the office jet is the default printer. It may be set to print to Microsoft one note for example.
I have inserted a new ink cartridge and it will not dispense the ink. I have removed all tape from...
(More)
I have inserted a new ink cartridge and it will not dispense the ink. I have removed all tape from the cartridge.
I am using the unit in a "stand alone" config. It will not send or receive a fax. Phone...
(More)
I am using the unit in a "stand alone" config. It will not send or receive a fax. Phone line is good. I probably have it hooked up wrong but I do not know. Help!
Half empty black cart stopped printing, error message to replace. New cart also didn't print. ...
(More)
Half empty black cart stopped printing, error message to replace. New cart also didn't print. Repeated cycles of clean and prime did nothing -- nothing but fill the bottom of the printer with a puddle of ink. Troubleshooting page suggests cleaning or replacing the cartridge service module. Is this possible on this machine. Is it a dead puppy or worth fixing?
Just installed a new color cartridge. It keeps saying that alignment failed and won't print in...
(More)
Just installed a new color cartridge. It keeps saying that alignment failed and won't print in color. Thank you.
