Question about RoadPro RPPI-2500W Inverter
High pitch alarm and fault light flashes, no power, how to stop
When I turn my Road Pro RPPI-2500 watt unit on, the fault light flashes once and the unit sounds a high pitch consistent alarm and the green light does not come on. This happened after our battery died and had to be jump started. Is there a reset switch or something?
    Brigadier General:
  • 4,090 Answers
There is no reset switch, unhook it from the present power supply to reset it. Then reconnect. It should have been disconnected before the battery was removed and then reconnected whist turned off when the battery was replaced
Posted on Sep 05, 2009
What is the # on the 1st diode on the board of a rppi road pro 1500 watt dc to ac inverter
The first diode on the board? No way can we tell what the first one is however, if it is the one that is on the input connection for the power then it is probably 1N5402
Jul 08, 2017 | Inverter Electronics - Others
Can the car alarm cause the battery in my chrysler cirrus to lose charge
if the head lights continue to flash of course the battery will go flat. every time the head lights flash there is 65 watts of power coming out of the battery. Have the alarm modulator checked out as it should only flash once or twice to indicate that the alarm is activated.
Dec 05, 2014 | 2000 Chrysler Cirrus
Protection light flashing and alarm sounding, unit was running and the unit just quit and the flashing light and alarm came on
Will the unit power up without the cb radio? I would suggest a short somewhere in the system if the protection light continues to shine bright.
Mar 24, 2013 | Pyramid (PS36KX) 600-Watt Power Supply
Connected a microwave (700 watt) and fault light turns on after few seconds on
engine has to be running with some high wattage items if your engine was running then your inverter is defective.
Mar 31, 2011 | RoadPro RPPI-2500W Inverter
I have a road pro rppi converter light links
It blinks because your computer is drawing too much current. Most of these give an exaggerated wattage range, and never give details about the true amperage available. the average laptop uses 3.0 to 4.X amps and is too much for these mini inverters. But they work fine on cell phone chargers.
Mar 24, 2010 | RoadPro AC/DC Power Inverter 80/100w
Have several non working inverters
I have had this happen a few times.
Sadly replacement is the Best option.
Repairs can be %75 the cost of a new one.
The best invert we have been using is a Pure Sine 1500 watt inverter.
Sad news but hope this tip helps.
R/
David
Jan 09, 2010 | RoadPro RPPI-2500W Inverter
Went u turn it on the red lite comes on and wont turn green and wont work its a road pro rppi-1500w
Sadly replacement is the best option. It is just not cost effective to get the inverter repaired.
The cost starts out about 150.00.
Best option is to take it back to where you purchased it and hope you can get a new one.
Hope this tip helps.
Am a seven each power inverters owner.
Recommendations: Purchase a Pure sine inverter 1500 watt. We have had one of these running 24 seven for almost a year now.
Jan 07, 2010 | RoadPro AC/DC Power Inverter 2000/5000w
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    Inverter not working
    unless you are into electronics it is cheaper to replace it! take it to a repair shop for an estimate
    May 28, 2009 | Cobra 2500w Power Inverter
    RoadPro RPPI-2500W Inverter Logo
    155 people viewed this question
    Top RoadPro Electronics - Others Experts
    jdthefixer
    deton8 von Splosion
    Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
