Question about Hotpoint Aquarius WF000 Front Load Washer
Lights flashing on WF320P
When the machine is turned on the following lights keep flashing wash enhance, reduce creases, rince hold, mini load, final spin ,on/off. When this happens the machine will not work, i used to turn off at plug and turn on again a couple of times and they would stop flashing this no longer works now.
Any help would be appreciated
I'm having same problem people have said empty filtter but i have done that and the water is running out but still flashing
so sorry wish i could help.
Posted on Sep 11, 2009
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
My hotpoint washing machine WF560 mini load and reduced creases lights are flashing and also the on/off light is also flashing, please help. Thanks
Heating eliment or PCB, is this when doing a prewash? or a normal wash excluding pre wash?
if you can manualy pump out and manualy rinse and spin, my guess is heating eliment is broke £20-£30
Jan 27, 2011 | Washing Machines
Hotpoint WF541 problem
Technical Fault is Pressure switch jammed on empty: check switch & module... in laymans terms its either a blocked sump hose or faulty pressure switch/module
Mar 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi my hotpoint wf541 will not run the start stop light and the mini load light are flashing i believe these are fault codes but have no refrences to what they are
I have encountered a similar problem. The following lights were flashing on and off:
  • On/Off.
  • Reduced creases.
  • Mini Load.
I also found that previously one of the 'lifters' inside the drum had broken off and someone had tried to put it back in place and continued to use the washing machine. After a short period of time the above mentioned flashing lights began.
I first suspected the pump, but this was fine. I then disconnected the hose which connects the hole from the drum to the pump and I found a child's sock blocking the hose. I removed the obstruction, put it back together and the machine worked perfectly. I also replaced the lifter (apparently these break quite often) and the machine has been working perfectly ever since that day.
I hope this helps. Good luck.
Apr 04, 2009 | Washing Machines
Reduce crease and mini load lights flashing on hotpoint wf541g. had pump failier and have replace with new on but still not pumping water out.
  • On/Off.
  • Reduced creases.
  • Mini Load.
Mar 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hot point wf541. have top 2 lights on wont pump
Hi.
The sequence of flashing lights is in fact indicating an error condition on your m/c.
It indicates that the m/c has failed to drain, possibly because the pump filter is blocked.
Your m/c is fitted with a filter system for the pump,
The filter may have become blocked, see care and maintenance in your handbook, in your handbook for details on how to check and clean the filter.
Also make sure the door is shut properly.
If after you have checked all these points, and it still does not work properly, then I suggest you have someone to look at the m/c, or replace the pump if it does not appear to be working.
Hope this helps.
Please leave feedback.
thanks.
Nov 30, 2008 | Washing Machines
Machine freezing with three lights flashing.
HI JOHNNYHEFF,
JUST GOT A NEW HOTPOINT STARTED TEST WASH ALL THE LIGHTS FLASHED SO SWITCHED OFF TRIED AGAIN NO JOY. TECHNICIAN COME OUT SAID THE CIRCUIT BOARD WAS GONE, NOT GOOD NEWS FOR YOU BUT THOUGHT I'D LET YOU KNOW!
Oct 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wma54
will help type this into a search engine it the user manual !http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMA50_WMA52_WMM53_WMA54_WMA56_WMA58_WMM59_small.pdf
Feb 15, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
466 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
