Question about GE WPRB8050D Top Load Washer
Amana top load washing machine
We have had this machine for ten years. Lately it overflows water underneath the machine. Can you make any suggestions to fix? This happens constantly
I had a problem like that shortly after getting mine...they told me not to use liquid fabric softener...the technician removed the front panel and there is a clear hose that was clogged up. He cleaned it out, and no more problems...I had it start to act up again a few years ago and pulled the panel off myself and cleaned out the hose. Again, no problems...Good luck
Posted on Aug 18, 2009
  • 20 Answers
U might have a faulty fill value.that the value the hoses hook up to on the back of the machine.
Posted on Mar 12, 2008
During wash cycle on Amanda front load washer, water leaks from the top down the side
Sounds like the door seal is shot. Try searching "amana washing machine door seal". You get YouTube hits on how to and suggested parts suppliers. Alternatively get a local technician to look at it.
Jun 16, 2015 | Amana Washing Machines
How to fix amana w10240534c washer wont fill?
check your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. no fill If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
May 31, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Adora washer has given several years of trouble-free service. Lately, water overflows the drain standpipe and flows on to the floor. Machine washes, spins and rinses just fine - the overflowing is the only...
  1. If the drain water is overflowing the standpipe then you have a problem with the house drain not the washer.You need to clean out the house drain or call aplumber to do it for you.
Jun 17, 2011 | GE WSXH208A Front Load Washer
Top load overflowing, I shut water off. What causes? Any way to drain other than bailing out water?
Overflow due to pressure switch fault, drop down drain hose to floor to Gravity empty
Feb 09, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Can't remove front panel on Amana washer
access through the back panel about 10 screws. Its likely the drain pump or one of its hoses.
Aug 23, 2009 | Amana ALW480DA Top Load Washer
Amana top loading super capacity LWD35AW leaking
Hello horshomom
Welcome
You said, You just found out my machine is leaking underneath somewhere and you haven't taken it apart yet. Any suggestions or ideas?
How old is the machine?
How much water leaks and when?
It usually is a leak in or around the drain hose.
I've seen a clamp vibrate loose near the pump.
You should be able to find it!
Let me know. Huuum
Please remember to leave a rating.
Oct 04, 2008 | Amana Washing Machines
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
AMANA DISTINCTIONS FABRIC CONDITIONER RELEASE
Hello Daddy 2,
Welcome to fixya
I'm Huuum and happy to assist you,
What is the model number and the year of the washer?
Front load or top?
A waiting your response!
Huuum
Dec 10, 2007 | Amana 3.2 cu. ft. Top-Load Washer
Washing machine
it has a little semi clear or black 1/4 of inch, long hose behind the control panel , who its attached one side to the level pressure switch and the other side to the tub. culd be only this three options clogged ,bented or unnatached this hose to one of the sides tub or switch easy fix
Jun 10, 2007 | Kenmore 20172 Top Load Washer
GE WPRB8050D Top Load Washer Logo
83 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
