Question about Sony VAIO PCG-K35 Notebook
Won't boot up,black screen says operating system not found.
If you hold down f10 and the start button at the same time it brings up the Sony recovery thing but won't fix it,why?
Well its tough to say, could be a harsh virus, or damaged registry. Try starting it up and as soon as it starts press f8 repeatedly until the safe mode menu is prompted, then from there pick a the option that best suits you, either safe mode or safe mode with networking. In just regular safe mode you can go in and remove harmful data from your hard drive. Maybe running under last know configuration might help. Let me know what happens.
Posted on Sep 05, 2009
My toshiba tablet won't let me go past the welcome screen
If this is under warranty take it back. If it isn't power the unit on with just the battery powering the unit. When you see the Windows splash screen drop the battery out after the screen goes black put the battery back in and press the power button. This should bring up the on screen menu telling you it failed to start or shut down correctly. Select, Boot in Safe Mode and see if the system will power on. If that fails you need to do a system restore. To access system restore options power the unit on and press and hold the F10 key, this will bring up the restore Windows options. From that menu select to restore your operating system. If that fails you will have to do a complete restore to factory default settings. If that fails you will have to replace the hard drive.
Dec 25, 2011 | Toshiba Tablets & eReaders
Tip
To Reboot or recovery from CD/DVD problem with OS "Aser"
If you don't press the Alt+F10 key combination or use the recovery CDs, can you get into Windows? Boot with the recovery CDs in. When at the Acer logo during POST, press the F12 key. Then, select boot off CD or DVD. Alternatively, you can enter the BIOS by pressing the F2 key at the Acer logo and go to the Boot tab. There, you can set the CD/DVD drive as the first item in the boot order.
When turning your laptop on, before Windows starts booting, a splash screen appears first (usually with the logo of the manufacturer). Look on the splash screen (usually at the bottom) for a key (usually F10 or F11), assigned for System Recovery. Some manufacturer(s) (e.g. HP) place the recovery files to a hidden (mostly) partition of the hard drive, the others give a Recovery CD/DVD with the laptop.
or
  1. Press the start button from the start menu depending on your operating system(win 2000,xp)
  2. Press Ctrl+Alt+delete combination from the keyboard.
  3. If you have a power button on your laptop keyboard,it could also be useful by pressing and hold it down for few seconds
N.B: "Ctrl+Alt+Delete" can exit you from usage and trigger a reboot
or Shutdown. Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up. Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot.
Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately. Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually.A few seconds should do unless you have additional problems.
All the Best!
on Sep 13, 2010 | Computers & Internet
Sony vaio lcd screen turns black after start up
graphics card software fault. start the pc and get it to bring up the start menu where you see options such as safe mode,usually holding down f8 when you boot. (If all else fails whilst windows is loading hold down your power button to power it off then it should automatically ask you what to do.)
select restore to known good configuration.
If that does cure it boot to safe mode and do a system roll back (restore) to an earlier time when it did work
If that doesn't work, also in safe mode you can try removing the graphics card drivers and forcing it to load windows default drivers. then update from the website.
If nothing works, not even safe mode then you'll need to use your windows disks or recovery discs. If you fear losing everything then try downloading and burning a ubuntu live disc on another PC and use that to load your laptop then copy and back up your files to another drive or usb stick using the ubuntu operating system.
Dec 02, 2011 | Computers & Internet
Hi, i have a Sony vaio and it was working fine until I shut it down overnight, the next morning I tried to turn it on which started out fine but as soon as the windows emblem started loading, it didn't...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
May 01, 2011 | Sony Computers & Internet
My husbands ex wife bought my step son a used HP compaq d530 SFF desktop. She set an admin password on it and now she cant remember what it is. Is there anyway to restore it back to the factory settings...
If you are talking about problem with your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) also
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Hope this helps
Hope this helps
Apr 08, 2011 | Compaq Computers & Internet
Acer Aspire One 521 does not boot. When holding down power button - battery charging light goes out and when I hold ear near power connector, I hear clicking noise every 2 seconds. Have tried taking...
To start the system recovery:
  1. Restart the netbook.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. In order to recover the system using Acer Recovery Media, an external optical disc drive is required.
  2. When the Acer logo appears on the screen, press the F2 key repeatedly.
  3. Press the Left Arrow key until you've selected Boot.
  4. Ensure that the external optical drive is plugged into a USB port.
  5. Refer to on screen instructions to set the first device to USB CDROM.
  6. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  7. Close the CD-ROM tray.
  8. Press the F10 key and then the Enter key to save the changes and restart the netbook.
  9. The computer will boot from the Acer Recovery Media
  10. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD. Note: If there are multiple Recovery CDs, please insert the first Recovery CD.
  11. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media you may purchase recovery media online. If your computer is unable to run the Acer Recovery process, or errors occur during recovery please contact Acer Support.
Dec 12, 2010 | Acer Aspire One PC Notebook
My acer netbook starts and you can see the screen works but couple seconds later it just turns black. Can anyone tell me why its doing that?
It appears that Operating system is failing to load. Try the steps below:
1. Turn Off the computer
2. As soon as you power button to turn ON the computer keep on tapping the F8 key, it will boot to Advance boot menu,
3. Select Safemode with the help of Down arrow keys and hit Enter
4. If the computer is booting to Safemode then there is no hardware failure, you can try full system restore.
To do a full system restore, please follow the below mentioned steps:
2. As soon as you hit the power button keep on holding the Alt key and keep on tapping the F10 key ie Alt+F10
3. It will boot to Acer Recovery Console
4. Select Full System restore and follow the on screen instruction
NOTE: This is erase everything from the computer including any data; pictures or music
Thanks and regards,
Anil.B.R
Nov 23, 2010 | Computers & Internet
Reset acer laptop to factory settings
During the system bios boot press and hold ALT + F10, that should start you into the system recovery options.
Oct 30, 2009 | Acer TravelMate 2300 Notebook
Recovery problem
you need the cd to restore any vista laptop call acer and order one sorry
Sep 02, 2009 | Acer Aspire 5610-4648 Notebook
Computer won't boot up
you must hold down the F10 key( for system recovery) when you turn on computer. hold down as computer starts up,hopefully it will then repair itself and boot up. If not,start up computer holding down F12 for advanced diagnostics and run some test!! Good luck
Mar 06, 2008 | Computers & Internet
Sony VAIO PCG-K35 Notebook Logo
294 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
