Question about Sony VPL CX4 Multimedia Projector
Horizontal blue lines in image
After the projector warms up, I get horizontal blue lines throughout the display. The image is still there, it is just a noticeable color shift.  Is my bulb nearing the end of its life or is it a projector problem?
  • abodiginal Feb 03, 2008
    Hey, i am having the same sort of problem except that I have blue and green horizontal lines along the projector and I am using a Marantz VP11s1
    . It is only noticeable in dark images (e.g. black) while in very light contrasts, it is hardly noticeable. Can anyone help? Please?
3 Suggested Answers
SOURCE: VW10HT screen filled with horizontal lines until unit warms up (5-10 minutes!)
I have a similar problem with our projector. It help to reverse the output for some reason. When reversed, all horizontal banding disappears.
Posted on Mar 08, 2009
Nic61
  • 1073 Answers
SOURCE: Menu flipped on screen
Hi Andy!
Yepp, you can do that, each and one of your projectors have separete settings. So you can run one hanging from the roof and the other one standing on a table if you want. How the picture is showing depends on how you set up the the settings in the specific projector. The the signal that comes to the projectors are always the same, its only the settings on the projector that can change that.
Good luck
Nic
Posted on Apr 22, 2009
How can I get rid of a horizontal line / band on acer x110p projector image
check the connector betwen the mainboard and the dmd board.mostly it is a loose connection.if that does not solve the problem, try getting the dmd replaced
this should solve the problem
Jan 17, 2013 | Acer X110P
Panasonic TC-P42C2 Horizontal Lines in Picture
problem could also be inside the display panel.
Jun 07, 2012 | Panasonic Televison & Video
White areas in the image are yellow and the black are blue-green
you have a few issues. first is the yellow in white. the light filter on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you may have to replace the whole optical engine. as for the flashing horizontal lines, the power supply isn't cooling down and the caps are drying out, causing fluctuations in voltage. so, replace the power supply.
Jul 04, 2009 | Toshiba TLP S30 Multimedia Projector
NEC LT35 color problem
If you're trying to project video, then the unit needs professional service. If you're trying to project from a computer, you may have a loose display cable, broken pins in one or both ends of the display cable, or broken conductors (wires) within the display cable. The computer sends its image information as a template of RED image components, GREEN image components and BLUE image components with the projector overlays to create the complete image with blended color values. (The computer also sends HORIZONTAL and VERTICAL synchronization signals, but those don'e affect the color content of the projected image.) That's why I'm suspicious of the display cable, conductors or pins.
Jul 02, 2008 | NEC LT35 Multimedia Projector
Projection horizontal lines and flickering
This is the problem I had with a couple of my projectors, one of them I just replaced the bulb and the other needed whole new brains (controller board)
Feb 01, 2008 | Dell 3200MP Multimedia Projector
Jan 22, 2008 | Sony VPL VW10HT Multimedia Projector
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
Horizontal lines traveling up screen
Sounds like a ground loop on the video signal. Try using a ground lift on your computer and or your projector.
Jan 09, 2007 | Sanyo PLV 70 Multimedia Projector
Sony VPL CX4 Multimedia Projector Logo
69 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
