Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
After updating firmware, power light is blinking
Besfr41
after updating firmware, power light is blinking can not reset. Can ping router but can not connect by web
    President:
  • 1,015 Answers
Is the router settings menu 192.168.0.1 or 192.168.1.1 available from internet explorer? The factory user password should be admin. If you cannot get the router menu to come up the firmware may have been corrupted. Hopefully you can get to the menu or try and re-install the firmware.
Posted on Sep 05, 2009
My wrt54g router keeps on blinking it all started when i pressed on the cisco systems logo because the light was orange so i pressed it and it turned off and the power led started blinking and the wlan led...
The first step that we need to do here is to hard reset the router. At the back panel near the power, you can see the reset button... we need to press and hold it for about a minute..
(If the power light continuously blinking, we need to follow this step):
Step1: On the computer connected wired via the router, let's force card and set static IP on the computer.
(for windows XP)
> Go to control panel -- network connections -- right click local area connection and we can see properties. Click properties and let's go to configure. On that configure button, we now see advanced tab. Click advanced tab and choose link speed or duplex and value will be 10 MBPS half and click Ok.
> Right click again local area connection and click properties
> Highlight internet protocol tcp ip and go to properties. Once properties is open choose use the following IP address...
Please set IP to 192.168.1.5 / Subnet : 255.255.255.0 / Default gateway: 192.168.1.1
> After assigning the static IP please go to start - run - type cmd. On the blinking cursor type there ping(space)192.168.1.1 and press enter. If we are getting Request Timed Out, sad thing router is already defective. But if we are getting "Reply from...' then we need to update the firmware.
(After hard reset and router power light stays solid then we needs to reset up the router)
Dec 20, 2010 | Linksys Wireless-G WRT54G Router
Tip
How to Fix Blinking Power Light on Linksys routers......
If you have a blinking power light on the router try to turn off the router for about a minute then turn it back on again. If the power light is still blinking follow the steps below to troubleshoot the problem.
1.HARD RESET- Reset the device to factory default.
a.Press and hold the reset button for 30 sec., after that
b.Unplug the power keep holding down the reset button for another 30 sec.
c.Then, plug back the power keep holding down the reset button for 30sec., after that
d. Release the reset button.
Make sure that you have downloaded the correct firmware version for your router from the Linksys website at http://www.linksys.com/download. You would be able verify the exact version of your router from the sticker at the bottom portion of the router.
2. Connect your PC to port 1 of the router.
3. Assign a static IP to the PC:
To statically assign an IP address
Windows 2000 and XP:
1. Click start, choose Control Panel
2. Double click Network Connections
3. Right click Local Area connections then select properties
4. Select “Use the following IP address” then enter on the IP address type 192.168.1.45 Subnet mask is 255.255.255.0 then Default Gateway is 192.168.1.1
Windows 95, 98 and ME:
1. Click Start, choose Settings then Control Panel.
2. Double click network.
3. Highlight TCP/IP -> for your network adapter (Ex. TCP/IP->Linksys Etherfast 10/100 Network Adapter)
4. Click Properties
5. Select Specify an IP address then under IP address, type 192.168.1.45 Subnet mask is 255.255.255.0 then
6. Select on Gateway tab. On New Gateway type 192.168.1.1 and click Add. Click OK all the way until it prompts you to reboot the computer.
7. Reboot PC.
4. Force the Ethernet card of the PC to 10Mbps
To force the Ethernet Card to 10 Mbps:
Windows 9x and ME:
Go to Start > Settings > Control Panel>Network > Highlight the LAN card you are using with a green icon beside it > Properties > Advance Tab:
-Under Properties set the value of:
“Media Type”; “Connection Type” or “Speed and Duplex Mode” to “10mbps/half-duplex”; “10BaseT” or “10Mbps HD”.
Windows XP and 2000:
Go to Start > Control Panel > Network Connections > Right Click Local Area Network Connection that you are using > Properties > Configure > Advance Tab:
5. Ping the router
a. On WinXP/2000:
Click Start > Run. On the Open field type cmd then hit OK. On the DOS prompt type ping 192.168.1.1
If it replies 4 times, proceed to the next step
b. On Win98/Me
Click Start > Run. On the Open field type command then hit OK. On the DOS prompt type ping 192.168.1.1
If it replies 4 times, proceed to the next step.
6. Proceed in upgrading the firmware of the router.
7. After upgrading the firmware, power down the router and then power it back up and see if the power light is now steady.
To upgrade the firmware follow the steps below:
Access the router’s Web Base Utility [http://192.168.1.1]> Administration TAB > Click on Firmware Upgrade > Click on Browse > Browse or look for the *.bin file > click on OPEN > Hit UPGRADE button. (Just wait for the message “You have successfully upgraded the firmware”) > Click on the Continue.
After upgrading the firmware try to turn off the router for about 30secs then turn it back on again. Hard reset the router then reconfigure it to work on the Internet.
Hope this procedure works for everyone......
on Jan 04, 2010 | Linksys Wireless-G Broadband Router
My router will not connect the power light keeps blinking
Check this tip out from Linksys. It is for a G VPN Router but you could use the same steps to troubleshoot. Title: Resolving Blinking Power or Diag LED on a Linksys Wireless-G VPN Router Article ID: 4982 If the Power LED on your Linksys router is blinking, this means the device is not ready. It should go off once the router completes its diagnostic test. If the Power LED won?t go off, it indicates that there?s a possible hardware problem with the router. To resolve this, you will need to perform five steps: Resetting the Router Assigning Static IP to the Computer Pinging the Router Accessing the Router?s Web-based Setup Page Updating the Router?s Firmware For instructions on how to reset the router, follow the steps below. Resetting the Router Hold in the RESET button at the back of the router for 30 seconds. Unplug the power to the router then plug it back in. If after resetting the router and the Power LED is still blinking, try resetting the router again for another 30 seconds. Then proceed with assigning a static IP address on the PC. For instructions, follow the steps below. Assigning a Static IP Address on Your Computer Most of the time, if the power LED on the router is blinking it loses its ability to assign IP addresses to the PCs connected to it, which is why you need to assign the computer a static IP address. After assigning a static IP address on the computer, check if the computer is still communicating to the router by performing a ping test. To ping the router, follow the steps below. Pinging the Router Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is 192.168.1.1. NOTE: If you?re using Windows 98 or ME, click here. Windows 2000/XP Step 1: Click Start, then Run. Step 2: When the Run window opens, type ?cmd? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. Windows 98/ME Step 1: Click Start, then Run. A window similar to Step 2 will appear. Step 2: When the Run window appears, type ?command? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. If you get good responses from the router, access the router?s web-based setup page to see if a firmware update is possible. For instructions, follow the steps below. Accessing the Router?s Web-based Setup Page In order to perform a firmware update, you should be able to access the router?s web-based setup page. Updating the firmware is one way of resolving the blinking power light on the Linksys router. To access the router?s web-based setup page, click here. NOTE: If you?re having difficulties accessing the router?s web-based setup page, the router is considered defective. If you?re able to access the router?s web-based setup page, proceed in updating the firmware upgrade.
Jul 21, 2010 | Linksys Wireless-G Broadband Router
Staus led not blinking after a fw update
You are going to have to find a software that helps you force reinstall the Firmware. Something went wrong somewhere, I know the software exists, i used it to install a 3rd Party Firmware on my linksys to gain Access Point Functionality
Apr 14, 2010 | D-Link AirPlus DI-524 Wireless Router
I have a WRTU54G-TM router that after saving settings changes now blinks the power light endlessly. Depressing and holding the reset for over 30 seconds has no effect, power light continues to blink...
Probably can't be saved. The only thing you could is update the firmware since it looks like you can get to the web interface. Pressing the "update" button when updating is different than hitting the "save" link when changing settings. If there is no newer firmware available, you should be able to downgrade it to an older version.
Feb 20, 2010 | Linksys (WRT54GC) Router
My LED on the BEFSR41 is blinking, and I can't get past pinging
  1. First you need to do a hard reset on your router. While the router is on, press and hold the reset on the router for about 20 seconds. Then, disconnect power from the router but keep holding the reset. Wait for about 15 seconds and then power on the router. Wait for another 15 seconds and then release the reset. You may need to stick a pen or a paper clip to push the reset button.
  2. Turn off the router for about 30 seconds and then turn it on agan. Check if your power light is still blinking.
  3. To assign a static IP address to your computer(in winXP); open Control Panel and click Network Connections then look for Local Area Connection.
  4. Right click on Local Area connection and then click properties. Then you will find a list of items used by that connection. Select Internet Protocol/TCP/IP then click Properties.
  5. Set IP address to Use the Following IP Address.
  6. The IP address you will configure to it is 192.168.1.2. The Subnet mask is 255.255.255.0. The Default Gateway is 192.168.1.1. Just leave the DNS server addresses blank.
  7. Click okay all the way out. Then try to ping 192.168.1.1.
  8. If you're able to get reply, then you may proceed in upgrading the router's firmware.
  9. Make sure also that firewall is off in your computer.
Hope this helps!
Nov 23, 2008 | Linksys EtherFast Cable/DSL Router
Help?
Something internally died. if you are willing to start replacing chips inside the thing. let me know the part numbers from the chips.
If you dont want to get into surface mount soldering I would suggest canning the thing or EBAYing it as parts.
Apr 30, 2008 | MSI Wireless-G RG54G3 Router
Power indicator keep on blinking
hello!
blinking power light after firmware upgrade sometimes indicates that the upgrade is not sucessful or the firmware that you load is incorrect.
-- try to reset the router for 30secs and check if the power light is still blinking
-- if its still blinking check your pc's ip address while connected to the router
-- if the ip address of your pc is invalid (169.x.x.x.) turn to manually assign static ip address to your computer and check if you can ping your routers ip address
-- if you can ping the routers ip address, upload the correct firmware to your router
-- if you cant ping your routers ip address still, reset the router again and try to ping the routers ip address once again
-- try to change port and cables
-- if still unable to ping the routers ip address, chances are that the router might be defective now
Apr 29, 2008 | Linksys Wireless-G WRT54GS Router...
My router keeps disconnecting the internet
a blinking power light suggest that the device is already broken. Go to the command prompt and ping the roouter. If you can still ping it then i suggest to upgrade the firmware of your router.
Oct 27, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
158 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
