Question about HP PhotoSmart C4480 All-in-One Printer InkJet
Just installed refilled color and black ink cartridges from walgreens.first refill on the color, second on the black. the printer does not recognise the new full ink levels....low still shows. any ideas? thanks
  • Annette Rae Jun 20, 2013
    It is not a refilled carteidge. It is new. The ink levels show they are full
  • Anonymous Mar 20, 2014
    refilled color and black cartrideges and print doesnt acknowledge it, at Costco
  • HP Master
  • 670 Answers
I found these instruction at out-of-warranty.com They seem like a possible solution.
Steps:
  1. Press Cancel and Power, at the same time.
  2. Then, the Unit will ask for a Key Combo, press blue, green, gray buttons (in order) for this.
  3. “Support Menu” should appear.
  4. Go to Resets menu and use the semi-full reset.
I hope this is helpful. Good luck.
Posted on Sep 05, 2009
Just installed refilled black ink cartridge on hp
By using refilled cartridges you will always have this problem. Each cartridge has a chip that lets the printer know when it is full or empty. By pressing the ok button you may be able to clear this message. However, most of the time you can still be able to print and ignore the message.
May 28, 2010 | HP Deskjet D4260 Printer
I had my ink cartridges refilled at Walgreens and now the light is blinking on my printer. How do I solve this? I have a deskjet 882C printer
try cleaning the contacts with a towel
if you see no progress one of your cartridge has been damaged due the refilling
check here the right way to refill your cartridge so not to be damaged
http://www.youtube.com/watch?v=TZNoUmS6hts for black
and
http://www.youtube.com/watch?v=5TTFOsGRPJI
for color cartridge
hope i help
pls vote me
May 13, 2010 | HP DeskJet 882c InkJet Printer
My lexmark X5410 will not accept the black and colored refilled ink cartridges from walgreens. It keeps reporting that the right cartridge is missing.
If you have refilled the cartridges 28 and 29, it's pretty normal that your printer won't print. Those cartridges are not for refill (they can be refilled, but won't work once the printer says they are empty). If you have refilled a 28A and 29A and it doesn't recognize the one of the cartridges, try removing them and clean the electric contacts with a dry cloth. Put them back in. If that doesn't help, I suggest you buy a new cartridge.
Apr 11, 2010 | Lexmark X4530 InkJet Printer
Refilled ink cartridges at Walgreens, printer won't recognize
Hello!
28 and 29 are not meant to be refilled. They can physically be refilled, but they won't work. That is because Lexmark has put in a smart chip that doesn't allow refill.
You need to buy 28A and 29A or 34 and 35, those cartridges can be refilled with no problem.
If you find my answer helpful, please vote. Thank you!
Aug 05, 2009 | Lexmark X2550 All-In-One Printer
Error: Remove and replace color cartridge
Because the software inside the cartridge was not reset. They do not have the electronic equiptment to do that.  I believe you woudl have to refill the ink before you got the empty mesasage?
Mar 13, 2009 | HP OFFICEJET PRINTER
Estimated ink levels are incorrect
The simple solution is to buy the HP cartridges. Often times,.. MOST times, aftermarket ink cartridges and refill kits are an inferior product. The difference is not always noticeable right away, but almost always rears it's head in the end. This is usually due to the ink being of a different viscosity than the original ink. Which leads to sloppy prints, sensor errors, leaky or dead jets.
Personally I recommend everyone buy Laser printers. With prices where they are these days, there is no reason for anyone to buy an inkjet printer. Lasers will cost more up front, but are much cheaper per page and generally longer lasting.
Feb 15, 2009 | HP PhotoSmart C4280 Laser Printer
Problem with Dell ink jet refill....
Are you using the Dell software to replace the cartridge?
If you where just replacing without running the software then it wont know you have replaced the cartridge.
Let me know.
Zod
Apr 24, 2008 | Dell 924 All-in-One InkJet Printer
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
My Hp does not recognize my color cartridge?
Sometimes the color bleeds over. Did you wipe down the contacts and clean the heads? Also, most of the cartridges have low ink sensors in the. Even if you have them refilled, they will still show as low ink. The only solution is to buy the new ones.... $$$$$$.
Dec 12, 2007 | Dell 922 All-In-One InkJet Printer
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Oct 22, 2007 | Lexmark X3480 InkJet Printer
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
396 people viewed this question
Seeker5211
Seeker5211
