Question about Uniden EXS 9966 Cordless Phone
Phone does not ring on base or on headset
I have a customer who is telling me that the phone nore the base station are ringing. any suggestions?
  • Anonymous Aug 15, 2008
    My Uniden dct7488 II does not ring on the corded handset or the cordless extension, the DO NOT DISTURB feature is off. The other house phone does ring
  • 138 Answers
Yea this might be due to signal problem in the phone line
Posted on Dec 08, 2007
I just got the Jabra GO 6470: The desk phone doesn't ring in the headset, so if you're not within hearing distance of the desk phone (but within the 300 foot range of the base) you don't know...
what i gather from what you have said is that the headset doesn't ring at all. this would indicate to me that the headset is not paired with the base.
normally when pairing devices the base station will look for the device but at the same time you will have to hold the headset power button for at least 5 seconds for that the other device can capture the signal.
i will look into this for you but try this method if applicable but the bluetooth devices do have to be paired in order to work.
Jun 15, 2011 | Jabra GO 6470 Wireless Headset with Touch...
We just bought a new uniden phone system and the Answering Machine keeps answering the phone after 2 rings. I set the base machine setting to answer after 6 rings but it didn't change.
If you have changed the setting on the base station and that did not work, power your base station off completely and try again if that does not work you have an out of box defect and need to exchange it.
May 06, 2011 | Uniden DECT 6.0 Cordless Phone ID
Ring alert on headset not working on Avaya AWH55
ask your local admin to change the ringe type in the station configuration
May 24, 2010 | Plantronics Avaya AWH54 (for Partner...
No ring tone on RTX Dualphone 3088 handset. All settings same as second phone which works.
there must be problem with the loud speaker or ringing speaker of the phone.take it to product care center
Mar 31, 2010 | RTX DUALphone 3088
I cannot hear phone ring on avaya awh75n headset hooked up to avaya 2410 phone, even with ring detector connected.
Is the phones ringer turned up? It needs to be loud enough to make the ring detector ring.....
Jan 21, 2010 | Avaya AWH75N Wireless Headset
Headset button will not lift receiver unless ringing
You should be able to press the button on the headset as many times as you like and the lifter will respond, whether the phone is ringing or not
Mar 24, 2009 | GN Netcom GN 9350 Wireless Headset
GN Netcom 9120 unexplained beeping
Actually what she was hearing was the ring tone in her headset when a incoming call comes in. The sensitivity on the handset lifter that picks up the ringing on a incoming call was set all the way up and was picking up interferance from the headset base as they have the tendency to buzz when placed right next to the phone. I just turned down the ringer sensitivity with the adjustment on the handset lifter and that took care of the problem. Thanks for your time.
Nov 06, 2008 | GN Netcom (9120-48) Wireless Headset
Whole house ringing when cordless phone is used
try deleting all headsets using primary headset (marked with no.1): 4-base/8-deregister/default pin '0000' and register them again using each headset (3-headset/8-register/same pin). it worked for me.
Oct 20, 2008 | Lands Phones
No 3 beep notification in the earpiece of an incoming call
I had the same problem and the cause was the handset lifter and not the earpiece--if the ringtone is too low at the lifter, it won't be detected and transmitted to the earpiece. Cranked up the ringtone and everything is fine.
If that doesn't take care of the problem you might look at whether or not you're using custom ringtones which might cause a problem. Switch them back to the defaults and see if the problem goes away.
Nov 28, 2007 | Plantronics CS70 Wireless Headset
Uniden EXS 9966 Cordless Phone Logo
46 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
