Question about Car Audio & Video
Blew a fuse in house have sorted fuse but alarm golng off and wont stop or reset have to remove fuse as short term solution
    Guru:
  • 1,326 Answers
Call alarm company, you have this posted in Car amplifiers. to get the best expert you may consider posting it in the correct section.
Posted on Sep 14, 2009
I replaced the battery in my 2008 Chevrolet Colorado and the factory alarm aka my horn won't stop going off. How do I reset my alarm?
pull the horn relay till its sorted
factory alarm may need a diagnostic scanner
might be a faulty module
Apr 16, 2017 | Chevrolet Cars & Trucks
My crazy fit machine just stopped then sparked from plate and blew my house fuses. what could b wrong
Dead short in electrical wiring, remove plug from wall socket. Need someone capable of testing electrical wiring.
Apr 28, 2015 | Exercise & Fitness
Horns keeps going off
hi..its not advisable to remove the fuse. you nee to sort the problem.
probably a short circuit. its also against the law to drive a vehicle without an audible alarm. god luck.
Mar 20, 2014 | 1999 Toyota RAV4
Oven light blew and now no power to the oven.
If you are not knowledgable in electricity, call for service.
This is an electrical short at the light, I have seen this before.
The wiring for the light has grounded to the oven. This causes the main fuse to blow. You will need to fix the short first. Then reset the main fuse/replace.
In the case of the wall oven, you may have to remove the oven to fix it properly. Depending on the model and where the short is.
Nov 25, 2013 | Zanussi ZBF360 Electric Single Oven
My aquabot keeps blowing fuses in or out of water
may be waterlogged. internal seal failed and its shorting out..
Aug 06, 2012 | Pool & Spa
Hi my car was running fine but I replaced my glove compartment and now the car wont start, the interior lights which come on when the door opens does not come on either and the alarm does not work. Please...
You probably blew the fuse for the glove box light which is related to the alarm system.
I forget exactly which fuse it is, but I believe it's a 10 amp mini fuse in the fuse box to the left of the steering wheel. You can just take a pair of needle nose pliers and carefully remove and inspect each fuse, or use a flashlight and try to see which fuse is blown without removing them.
If you have a test light it's the easiest way to check. Each fuse has 2 small metal tabs on the flat end. If a fuse is good it will light the test light at either tab, if it is blown it will only light from one tab.
Jan 30, 2011 | 2002 Volkswagen Passat
Where to look for the short that keeps blowing the fuse
There are a bunch of places it could be. Look for anywhere the wires go over, around or under the frame, trans bell housing. It could be a component that is bad causing a short also. I would look for a bad wire short to ground though as this is the most likely cause.
Jun 02, 2009 | 1991 Jeep Wrangler
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
