Question about Cell Phones
Phone doesn't show signal strength when there is signal. My wife's phone shows 5 bars and mine shows none. Calls are not coming through.
  • lailapaxton Sep 14, 2009
    We solved our problem by buying a new iphone. Thanks, anyway.
  • kaisarit May 11, 2010
    GENERAL PROBLEM
    » Nokia Solution » Motorola Solution » Sony Ericssion Solution » LG Solution » Samsung Somution
    UNLOCK CODE
    » Nokia Unlock Code » Motorola Unlock Code » Sony Ericssion Unlock Code » LG Unlock Code » Samsung Unlock Code
    kaisarit18
My treo 700 wx has low signal strength
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Dec 08, 2012 | Palm Treo 700wx Smartphone
SIGNAL STRENGTH IS EXTREMELY POOR COMPARED TO OTHER PHONES ON SAME NETWORK
your phone antenna have some problem just open your phone if your phone out of warranty and make sure your antenna contact point is clean
May 21, 2012 | Motorola Mobility W173 Cell Phone
V9 works fine in town but over the first hill-5ks no reception.Have v3 which shows 5 bars where this shows none.Settings are on auto so if anything there I should get it.Tried all combination settings...
Since the v9 works fine in town, then it simply means, it is not receiving any signal from the hill.
It has a weak signal strength and might receive little or no signal at all from the hill. So for hill tops, try using another phone, but for town use, you can use the v9.
The phone is not in any way faulty, it just is not built to receive signals from such heights. If you have the phone checked, you will not detect any fault simply because the phone is not faulty.
Take care and good luck
Dec 02, 2010 | Motorola Mobility MOTORAZR2 V9 Cellular...
I cant recieve calls on my nokia n95
Hi, since it is a nokia phone, and on the phone it has service signal bar showing on the screen of the phone, Just apply this codes #33#0000#( to cancel any beared calls(both in and out going calls and #002# ( to cancel any call divert on the phone.
NOTE: it will only work if the service signal bar on the phone the makes you know that there is service on your is full. If not, that means the phone network will be the problem which you will need to consult repairer.
Take care.
May 19, 2010 | Nokia N95 Cellular Phone
The County Sheriff broke my door down while I was not home. Left a John Doe Search Warrant on the table. They tore my house apart but didn't take anything. Mine and kids' Laptops were with us, but now we...
> can't access 'net through router
When you "view available networks" on your laptop, do you see the SSID for your router as being present? What's the "signal strength" (poor? none?)
Have you tried powering-off the router, waiting a few seconds, and then powering-on the router, and then retrying on the laptops?
Have you tried an Ethernet cable directly between the network-port on your laptop and one of the LAN ports on the router? That should give you a fast connection, because it is not "wireless".
> cell phones all drop calls
Weird. Did they wrap your entire house in metallic foil, to "block" signals from the cell-phone tower to reach inside your house, to your phones?
If not, why has the signal-strength dropped so much?
What happens if you take your cell phone just outside your home? a few houses away? a few blocks away? a few miles away? Does the signal-strength increase "sharply" at some distance?
With your cell-phone, walk all the way around the outside of your house, to see if there is a "good" side or a "bad" side. Repeat on the inside, and see if you can draw a "map" (4 bars here, 1 bar there).
Apr 09, 2010 | Computers & Internet
I live in a rural area and can't get a signal
That is a common problem. I have had that issue myself. Motorola's pull a better signal in a rural area than LG. I would see if you can do a return exchange for another like phone that is a Motorola. It's the way the phones are made that makes the signal strength different.
Nov 12, 2009 | LG enV3 VX9200 Cell Phone
Can't display pictures on web pages
I called HTC Touch customer support. Found out that using soft reset button on bottom right of phone corrected that problem. Also found out that another problem I've been having - not receiving calls when phone in sleep mode has been partially corrected by new software. I say partially because we have 2 of these. My wife's phone is now working reasonably well but mine still misses calls. I think my problem could be related to these phones not having very good receiving strength signals vs other ones I've had. I miss calls while sitting at my desk at work. Never had this problem with other phones in same location. I guess the internal antenna just isn't as good as other phones. I also drop a lot more calls with this on the highway than with other phones - that's why I suspect the phone and not the service provider.
Nov 06, 2008 | HTC Touch P3450 Smartphone
Bluetooth connection... with no audio. the pair appears easily with the LG Dare phone, with signal strength and battery strength showing on the display, but there is no audio
Though the phone paired, is it compatible?  Some phones will pair but not work.  The salesman should have told you about the website that shows which phones are compatible.  When the button is pressed does the radio go quiet?  Is the radio on?  Do voice commands work for the center stack?  will it ring when someone calls you.  If the phone is good, then try the HFL unit.  WWW.HANDSFREELINK.COM
Jul 17, 2008 | 2007 Acura RL Sedan
Nokia 6230i
Sounds like a deactivated sim card or a barred handset. Ie, reported lost or stolen
If you place an active O2 sim into a blacklisted handset your phone will not show any signal strength
at all! If the handset is a Nokia then a
"SIM card registration failed" message
will also be displayed.
Apr 01, 2008 | Nokia 6600
Cell Phones Logo
98 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
