Question about Sony KP-51HW40 51" Rear Projection Television
Light blinks on and off where the power switch is in front
We were watching tv and it just switched off and started to blink a red light by the main switch
  • 7 more comments
  • tuafono_teio Sep 05, 2009
    yes it blinks off and on continuously
    My tv blinks off and on continuously I need to know what to do and how to fix it also if it is worth fixing
    It just blinks continuously there is no pause it has the picture that represents the standby button and also the picture two circles together.
    also my tv is a Sony KP-EF41
    Sorry no nothing is on the screen I was describing the light flashing on the standby button there is no picture or sound.
    Sony EP-EF41SN2
    I dont know what DVM is as this is the first time I have had a tv like this. All I see at the back is 110-240V 50/60 Hz 160W
    I hope this is what you wanted me to provide?
    Yes I am willing to fix myself is it a big job? I want to give it a go please advise me
    Just wandering from all your experience how much am I looking at in getting this tv fixed if I do get a technician to look at it. Is it worth it really?
  • 10,594 Answers
Please count LED blinks as there would be 3 seconds interval in blinks.
This is an error code so count pause to pause and get back to me to move forward.
Thanks.
Posted on Sep 05, 2009
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Sep 05, 2009
    Please intimate exact model number as it seems incomplete.
    Can you post screen image of TV as you are saying "TV has picture that
    represents the standby button and also the picture two circles together."
    This is confusing me.
    Thanks.
    Sony EP-EF41SN2
    Thanks, It is Sony KP-EF41SN2 rear projection TV.
    I have its schematics and related info.
    Let me know can you test/ check power supply output voltages with DVM?
    I will let you know connector number to check volts on it.
    Thanks.
    DVM is digital volt meter that is instrument of techs to check volts and electronic parts in TV.
    Are you still willing to repair TV by yourself or thinking about local TV tech to fix it?
    Thanks.
    Yeah, it seems big job because it might needs to replace few parts in PCB and prior to that we have to find out bad parts by testing output volts and taking out suspected parts. If you have no experience of TV repair, I would recommend to have local TV tech services.
    Thanks.
    Shahid Electronics Sep 06, 2009
    worth it really?
    Repair would cost around $250 or so,
    I would recommend to ask repair estimate before and that will better input to decide to repair it or not.
    Thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check how many times does the light blinks. The number of times the light blinks indicates a diffrent fault. Please see this info for more detils--
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit go to the standby mode then display the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit go to the standby mode then display the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (fly back transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not Resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the "D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Please check out the number of blinks and then you can verify the type of fault that has occured.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Hi, I have a Panasonic Plasma TV and Was recently watching it when all of a sudden the screen went out. The light to the tv only blinks now and there is no picture. Any ideas what this problem isn't?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 17, 2015 | Panasonic Televison & Video
When you switch the TV on with the remote or on the TV. The TV comes on for a few seconds or minutes then switches itself off. The red light on the front of the TV flashes. Please HELP. Thanks Mary.
Apr 15, 2015 | Televison & Video
Samsung PN58c590 plasma tv
Short circuited component/s at its main board. These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy.
Feb 24, 2014 | Samsung PN58C590 TV
Some time ago, I was watching TV, then, all of sudden, the TV screen has gone, just like 'blank'. The main power (red light) keeps on blinking. Normally, it is just on, not blinking. TV doesn't respond at...
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 24, 2013 | Bush 5693D 24" TV
My TV just turned off and the red power light started to blink, why?
In most cases this error will dissapear by switching your television off at the wall and then switching tv on (via power button on TV front/side panel) "Whilst still switched off at wall outlet"
This will discharge all capacitors inside the TV
Now turn TV power button off then switch back on at the wall outelt then try to resume watching TV.
This solution may clear the blinking red light however if it does not it could be a more serious issue such as a blown fuse or even blown control circuit on the TV, In this case you should decide whether a repair is economical or to replace the TV.
This solution is based assumption this a CRT television and not an LCD.
Hope this helps
Feb 28, 2011 | Toshiba Televison & Video
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
Mar 11, 2017 | Samsung Televison & Video
Toshiba 57h81 red light blinking
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 14, 2017 | Toshiba 57H81 57" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
