Question about Brother MFC-640CW All-In-One InkJet Printer
PRINTING My printer seems to be printing out of alignment i have been to the alignment programe but where it says match the nearest to 0 there isn't one anything like it! Also my heads seem to be blocked tried cleaning several times but doesn't work I have another brother with error 43 on it can anyone help there?
  • 832 Answers
The alignment has to be fixed by service personal. Theres no way you can fix it by yourself because special software and drivers needed which are only accessable for service dealers.
Run a power purge. Do use nearly full carts, because it consumes some ink!
Press menu then start black copy then fourtimes arrow-up (tel.index). press 7 then 6 then 3 then start black copy. Repeat power purge. Leave meaintenance by pressing 9 then 9. If there is still trouble with color the printhead needs replacement.
Error43: white flat cable of print head not connected correctly.
Check ph and circuit board if connected and placed well. If it is good and still problems left, the circuit boards (ph and/or main) are defective. Needs replacment then.
Posted on Dec 08, 2007
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
My Lexmark Z2320 only printing pink.... 3/4 full black cartridge, and 1/2 full color cartridge. Why only printing pink....
If your printer is only printing one color, it is a clear sign that the printer is in need of a head cleaning, and possibly an alignment. The instructions to do so are as follows according to the Lexmark website:
  1. Load plain paper.
  2. Then do one of the following:
    - in Windows Vista, click pattlnk_852008_1527-vista-start-button.gif.
    - in Windows XP and earlier, click Start.
  3. Click All Programs or Programs, and then select the printer program folder from the list.
  4. From the printer folder, click Maintenance - Align Cartridges.
  5. Click Print.
  6. Follow the instructions on the computer screen to finish
  2. Do one of the following:
    - in Windows Vista, click pattlnk_852008_1536-vista-start-button.gif.
    - un Windows XP and earlier, click Start.
  4. From the printer folder, click Maintenance - Clean Cartridges.
  5. Click Print. A page prints, forcing ink through the print cartridge nozzles to clean them.
  6. Print the document again to verify that the print quality has improved.
Complete both of these processes, and your printer should begin printing normally again.
Apr 07, 2011 | Office Equipment & Supplies
We just put new ink in and it prints out fuzzy . how to fix it ?
Every time you replace ink you need to do an alignment. To do this follow these simple steps:
  1. Press the Ink or Ink Management key on the control panel.
  2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
  3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
  4. Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
  5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
  6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  7. Press Stop/Exit.
Mar 02, 2011 | Brother MFC 210C All-In-One InkJet Printer
I have a Brother MFC-210. It was working well. When I moved and hooked it back up. It was printing some pages fine and then it started printing double like 3d. Started with a few words. Now the whole page...
Check the alignment. Press the key for Ink or Ink Management on the Control Panel. Select Test Print (the up/down arrows) and hit Menu/Set or Set. Select Alignment and press Menu/Set or Set. Next hit Mono (Black) Start. Look at the Alignment Sheet that prints out. Press 1 if the number 5 sample matches line 0 for both 600 and 1200 DPI samples. Press 2 and then the number for the line that matches that matches the 0 sample.
Then press Stop/Exit. Repeat this for color printing by using the Color button.
You should also check the Print Quality. (Very similar menu choices - just choose Print Quality after choosing Test Print but you only need to hit the Color button to print the test sheet.) This will initiate a cleaning cycle for any poor quality ink test pattern. You will need to respond Yes or No for the print quality and each ink (if you answered No). If you do the cleaning 5 times with problems, replace the cartridges in question.
Finally try cleaning the printhead (Press Ink or Ink Management and then 1 for cleaning) If 5 repeats do not help, contact Brother support, the print head may need to be replaced. (Unfortunately, this isn't the only reason for the problem. Once you put in a print head, it isn't returnable. It could be that the entire printer is ready for recycling.)
I hope this helps.
Jun 24, 2010 | Brother HL-2040 Laser Printer
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
How do i align my printer, it's printing blurry
Setting the Alignment:
  7. Press Stop/Exit.
Apr 01, 2009 | Brother DCP-120C All-In-One InkJet Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
Printer alignment
From Brother's website, I found the following regarding alignment:
  4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
  7. Press Stop/Exit.
The webpage for this is:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000059/faq000259_007.html?reg=us&c=us&lang=en&prod=mfc420cn_us
I hope this resolves your problem.
May 20, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 240C alignment problems
I have figured it out! I have a Brother MFC 240CN and I was having the same alignment problem and I followed the instructions from the printer prompt as well as the manual and it does not work.
So, this is what I did. I ran the alignment test print, then when it asked if it matches, I would say "No". And then I would pick number "8" to be the one that most closely matched "0" regardless if it did or not. I did this for the 600 and 1200dpi. Then when I ran the alignment test print again, it looked better! So I repeated it again and again picking "8" each time and it looked better with every test print. After about 4 or 5 tries, it looked normal again!
I hope everyone else with this problem will see this response and I hope it works too. I was getting so frustrated with this problem. Now I don't have to get it serviced or buy a new printer!
Sep 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC-640CW All-In-One InkJet Printer Logo
227 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
