Question about GE WBSR3140DW Top Load Washer
Model wjsr4160g1vww wont agitate or spin out the water , fills up goes seeming goes thru the cycle clothes are dripping wet , but the water is draining machine is 18 months old
  • 4 more comments
  • karen_lilly7 Sep 05, 2009
    washer will fill and pump will drain will not aggitate or spin, beltdriven washer does come on there is a small green light on top of motor flashes 6 times pause and 6 times again
    need steps to remove the agitator please respond waiting on the 2nd question this is the 3rd
    so the inverter would stop agitation and spinning , if that is the case how much for the inverter thanks
    hey localwonder, if this is not the problem and we buy the inverter , which you say is the problem would we get credit for the invert cost.
    yes we will try it localwonder was good
  • karen_lilly7 Sep 10, 2009
    washer model is wjsr4160g1vww taked with localwonder on sat the 5th purchased the inverter installed last night the 9th washed 2 loads agitation and spinnig sto pped on the 3rd load same problem but now green light is flashing in sequence of 7 on the new motor/invert help
  • 6,784 Answers
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cuase this dissruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
Posted on Sep 05, 2009
  • 2 more comments
  • Michael Masters
    Michael Masters Sep 05, 2009
    Thanks for the extra information. That blinking light is signaling and issue that concerns the Motor. this motor has an on-board inverter. this is the issue. it is damaged. It is built for 2 speed action. the inverter is the culprit.
    Check to make sure of the connections between the timer and actual motor wire harness. make sure that the harness is connected property and not fared in any way. if the wire harness is Ok, replace the Motor/inverter.
  • Michael Masters
    Ok. The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly, which is removable as well. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
    Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to preform a combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
    Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
    If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
  • Michael Masters
    Yes, the Motor/inverter is responsible for the rotation of the basket and agitator as well. You can order by clicking the link below
    Motor/inverter--$157.85
  • Michael Masters
    I'm not sure i understand your question correctly. Fix-ya will not reimburse you the cost of the replacement part if it doesn't fix the issue. From what you have stated above in your post, the likely issue will be the Motor/inverter. You stated that there is a blinking light that flashes 6 times just above the motor housing. this is exactly where the inverter is housed.
    I recommend to use all the information i posted for further troubleshooting, if all checks out ok with the above stated problem areas i have listed, the likely culprit will be the Motor/inverter.
    Hopefully, I have answered your question properly.
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Whirlpool type 107
Sounds like the clutch may be slipping. Does it go into a high speed spin?
Aug 18, 2013 | Washing Machines
Agator not spinning
There is no belt on that unit. It is a direct drive machine. When the unit goes into the wash cycle, does the motor run but it does not agitate?
Nov 28, 2012 | Maytag MVWC400XW Centennial 27" Top-Load...
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
10yr whirlpool toploader wash machine no spin/agitat. but works?
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 08, 2009 | Whirlpool Washing Machines
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
Sep 17, 2008 | Frigidaire ATF6000ES Front Load Washer
GE WBSR3140DW Top Load Washer Logo
14 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
