Question about Concept Car Audio & Video
I recently bought a used car with a Concept DVD player in it with no manual, I can't get the volume to work. Does it run through the stereo speakers?
2 Suggested Answers
SOURCE: concept mobile dvd
I have a Concept DVP 500 dvd player the audio quit working through speakers, was programmed for a certain station. what could the problem be or solution to fix it
Posted on Jan 29, 2010
We have a picture but no audio, when connecting Zenith DVB211 DVD) player to Vizio CABLE TV...
If you are using the original cable, is it fully seated? Is the volume on the player up? Or is it all the way down.
Does the playback set recognize the audio source? A work around if using the original cable- use a 1/8 inch mini double ended stereo cable like some computer speakers use and plug into the headphone jack over to the 1/8 inch stereo "Audio In" connector on the set.
Jan 24, 2012 | Zenith DVP615 Portable DVD Player
The volume has went off on my tv. its a samsung le26b450c4w
First verify that the mute is disengaged (toggle the mute button). Second, check the sound configuration to make sure the internal speakers are on, or check the sound output to make sure it is going to the inputs of an external audio amplifier (stereo receiver) and that the external amplifier is working. Try a different input source - perhaps the problem is your cable feed or DVD player.
If the internal speakers are on, the volume is up, and you still don't get any sound from a known-good source (TV channel, DVD player, etc.), then try running the sound to a stereo system as described above.
If that works, you may have a shorted speaker amplifier (depending on the set's design, this may blow a fuse supplying power to both left and right amplifiers or a speaker protection circuit will keep the speakers disconnected). These aren't usually hard to repair, but if you find a blown fuse, fix the amplifier before replacing the fuse or you'll just waste another fuse.
Jan 09, 2012 | Samsung Televison & Video
Repeated off and on
speaks are hooked up wrong or speakers are blowin.
Apr 01, 2010 | JVC KD-SX980 CD Player
Volume won't turn upon my panasonic cq-vad7200u car stereo
this may be a pre amp only deck
and if it is ou have to buy amplifiers to make the speakers work
May 07, 2009 | Panasonic CQ-VAD7200U Car DVD Player
Volume is not working
get a splitter that allows you to plug 2 sets of headphones in the portable dvd player.
The sound is the only place were this machine falls short. The sound is okay at best with the built in speakers, but any background noise makes it nearly impossible to hear anything from them even with the volume all the way up. Not surprising since due to the size of the player the speakers are only a little bigger then headphone speakers, but with headphones or portable plug-in speakers the sound is superb. Besides the sound the only 2 complaints are that you can not control the volume with the remote and that the power switch is too easily turned on by accident (do not travel with the battery attached or you will find you have no charge when it comes time to watch a movie). The battery lasts 3.5 to 4 hours, long enough for 2 short movies or 1 long one.
also checkout The volume button is on the right side of the uint.
, headphones are a must, or get a device to play the audio through your car stereo ($15-$25). The player has the option to either input or output the A/V so you could play video games on the run or you could hook up a VCR and watch VHS...be creative
Apr 01, 2009 | Shinco SDP-1850 Portable DVD Player
Concept mobile dvd
Apr 07, 2008 | Concept Slot Load Half-Din DVD Player Car...
Car Audio Cutting Out
stereo is detecting a short , or low load on speaker wire and or speakers .Go behind car stereo , disconnect all speakers and apply a known good speaker to one of four wires and see if volume works normally ..If it works use same speaker on all outputs one by one ..If all are okay then you should figure out what speaker and or wires are causing issue..Also make sure your ground is okay
Dec 01, 2007 | Pyramid 4 X 10 SPEAKERS Car Speaker
Truck dvd player concept/pronto
Does it possibly have a reset button you could press with a paperclip? If not, try disconnecting the constant power wire for ....let's say an hour, and hooking it back up.
Nov 28, 2007 | Concept Slot Load Half-Din DVD Player Car...
Losing treble at higher volume
There are two things. First check the sound settings of the DVD player. It might be putting out a lower quality sound on the CD side of things.
Secondly try to determine if the speaker tweeters are working. Connect the speakers if you can to another sound source. If the speakers are good and the settings fine. Then you have a fault in the amp unit.
May 26, 2017 | AAD C-600i Main / Stereo Speaker
Car Audio & Video Logo
Top Concept Car Audio & Video Experts
jamie suver
Level 1 Expert
Robert Rankin
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
