Question about Craftsman Garden
Idles high and lower nearly konking out
I have a craftsman model 917.387.224 i know u wont find it in the search engine its weird its a 4.5 hp 20 inch push mower nearly new bought it the other year it starts right up i can make it run if i hold in the primer ball nicely but as soon as i let off if dies out low to where it wants to shut off any advice it has good spark plug carbs good as far as i can see i cleaned it i dont know what else to do
  • 389 Answers
Remove the air filter box and replace the gasket between the box and the carburetor
Posted on Sep 14, 2009
  • Chuck
    Chuck Sep 19, 2009
    Owners manual (english/spanish)
    Part # 165650 from Sears
Craftsman Lawn tractor 20 hp twin clynder briggs with a 42 inch deck I need a model number the plate is unreadable
Maybe this will help.The mower deck part # 165892. Mower Deck Assembly 42" I not sure of the model # . I also don't know your tractor's model # either. This part # for the 42" mower deck,is installed on a 18.5 HP Craftsman Lawn Tractor. I believe there isn't any difference between a model !8.5 HP and a model 20.0 HP, tractor when it comes to a mower deck. B.Locke
Sep 14, 2015 | Craftsman Garden
WHY DOES MY CRAFTSMAN BRIGGS POP LOUD WHEN I TRY TO START IT. iT WONT START NOW
sounds like you need to adjust the valves. do a google search with your engine model number and "valve adjustment".
Jun 14, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a briggs model 407777 that was idling up and down from near top range to bottom. Found some dust in the carb intake and decided to cliean the carb. When removing the manifold/ carb, I took loose...
These can be tricky, but your on the right track. With throttle set on high (engine off), turn governor linkage in the same direction that opens throttle valve in carb wide open, then turn the governor rod in that same direction then tighten bolt on governor arm. This is a static setting. The high and low idle is most likely a dirty carb so assuming the carb is now clean your idle should be better. Hope this helps. Good luck!
Aug 12, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine will not idle at high r[m
idle and high RPM are at opposit ends of running speeds.
what do you mean?
Aug 02, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Where is the spark plug located on my craftsman lawn tractor model 917.273360
James, it is at the front of the engine. It is next to the 4" by6" metal cover that says OHV. It is on the right hand side ( sitting on the tractor), There is a black wire the size of a pencil ( diameter ), hooked to it. It is set deep in the engines cylinder head. There is a rubber boot over the end of the spark plug. Remove the rubber boot, you will hace to grip it hard and pull it off. Then you will be able to remove it, using a deep 5/8" socket with a 4 to 6 inch extension.
Hope this helps, if you need more let me know.
Matt
Dec 02, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
What engine other original will fit in mower?
Nearly any single or twin cylinder engine with the same configuration (ie. vertical shaft) will fit under the hood of a craftsman that used to run 20 HP.
Jul 26, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
2010 Craftsman Lt 2000 deck height adjustment?
just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Jul 31, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
How do i remove and replace the oil filter on my model 917.271910 craftsman tractor
Down on lower left side of motor is a pipe nipple about 2 inches long with a black plastic cap . Half twist it by fingers and pull off.Oil should drain.
Apr 30, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 13 hp lawn tractor slipping in reverse and low gears
Really hard to say without looking at it but it sounds like a pully has seperated or is trying to come apart they are made in two peaces.
May 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
183 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
