Question about MB Quart Reference RVF 216 Component Speaker System - 6 1/2" Reference Series Polypropylene Cone 3... Car Speaker
Very little sound coming out of my front left speaker in my honda accord
I have a 1997 honda accord 4 door lx sedan. I have 2 50 to 110 watts mb quart reference rvf 213 us in front and mb quart refence rvf 269 140 watts with crossovers in the side of the front doors. I have a sony mex dv 2000 in dash dvd player and jl a4300 amp. I have 2 speakers in the front and 2 in the back. when i do a sound check to check each speaker the front left is barely audible the front right is loud and the back right is loud the back left is loud but not as loud as the 2 individual right speakers and the 2 peakers sound on the right are a lot louder than the 2 left side speakers, how can i get the 2 speakers on the left side of my car to sound the same volume as the right side of my car so the sound is the same coming out of alll 4 speakers. thanks
  • 70 Answers
Maybe the equilizers messed up
Posted on Jan 22, 2008
How to fix a driver door lock problem in honda accord sedan 2014?
The arm that controls the lock probably came loose. You need to take out the door panel, the plastic sheet, and reattach it.
Jul 27, 2014 | 2012 Honda Accord LX Sedan 2.4L 4-cyl....
Location of fuel filter
on the frame on the drivers side
Mar 03, 2014 | 2009 Honda Accord EX
I have a 1999 Honda Accord with a CD radio with no extenal speaker connection. I have a new XM radio and want to connect the radio to the speaker system. How do I find the place to acces the cars...
Hello! Pull the radio...There is a connector with the following speaker wire colors...
Front driver door + Red/Green
Front driver door - Brown/Black
Front pass. door +Blue/Green
Front pass. door -Gray/Black
Left rear+ Blue/Yellow
Left rear - Gray/White
Right rear + Red/Yellow
Right rear - Brown/White
If the vehicle is an EX the left and right Tweeter's are the same as the Front drivers/Passenger door speakers and merely connect to them...
Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Dec 25, 2010 | 1999 Honda Accord
Replace a door speaker in a 1997 honda accord sedan
It's pretty easy to do. First, get a pry tool from a parts store to aid in getting the door handle off. While you are there, get a pry tool to aid in getting the clips off from around the outside of the interior door panel. Take those items off, unscrew the door arm rest screws and you're golden. unscrew the existing speaker, match the size with a new one, hook up your wiring, test the speaker by turning on the power and playing the radio and once you confirm you have a working speaker, put it all back together.
Sep 21, 2010 | 1997 Honda Accord
How many quarts of oil does it need?
95 honda accord ex 4 door sedan takes 4.5 quarts of oil if changing the filter 2!!!!
Apr 10, 2010 | 1995 Honda Accord
1999 Honda Accord LX sedan trailer harness install help
The Running Lights are BROWN, the RIGHT Turn is GREEN, the LEFT Turn is YELLOW and White is GROUND.
Nov 11, 2009 | 1999 Honda Accord
I NEED NEW SPEAKERS FOR MY FRONT DOORS IN MY HONDA CIVIC COUPE 1997 BUT DONT KNOW WHAT SIZE TO BUY?
Not sure if you had a sedan, hatch, or coupe but here is the info you requested. Front door speakers measure 6.5" with a top depth of 1.75" (you have no depth problems here but any larger than 1.75 and you might have to cut out the factory housing.)
If they are door or kick panel speakers, you have to remove that panel to extract the speakers. Then measure them with a ruler; better yet, make a pencil outline of them (outside rim) and also where the mounting holes are. Then, when you buy new speakers say at Best Buy or some such, you will get the proper size, mounting and DEPTH. Unless you want to build all new mounting enclosures, you have to be sure of all the size measurements so that your new speakers will fit.
Wiring them is easy. There should be instructions. Speaker wires do have a + and - side, and if you cross them, the speakers will work but won't sound as good. Also be sure you have the POWER to drive your new speakers. Buy speakers of the same "impedence", measured in ohms right on your speakers.
Also, in here you can find the 1997 Honda Civic Service Manual.
Easy job, good luck (remember rated this help).
Oct 14, 2009 | Honda Civic Cars & Trucks
Japanese import integra type r stereo wiring diagram
Try the following, this is an 1997 USA Integra
Radio Constant Wire 12V+: Blue/White
Radio Switched Wire 12V+: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Left Rear
Front Speakers Size and Location: 5 1/4′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Front Speakers Size and Location: 6 1/2′ Side Panels
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Oct 06, 2008 | 1997 Honda Accord
Tweeters fading out
Turn on the HPF it will definatly clear up the sound.
Aug 07, 2006 | MB Quart DSD 216 Car Component System
Car Audio & Video Logo
535 people viewed this question
Top MB Quart Car Audio & Video Experts
hoyzee1
andrewcahoon
Are you a MB Quart Car Audio and Video Expert? Answer questions, earn points and help others
