Royal, 1951 KMG Bell will not ring, even after setting right margin! Is it broke, or is there something I am not doing? Thanks!
  • 328 Answers
The bell is in the rear of this machine. Look and make sure the ringer lever is moving freely. May have to place a little oil on the pivot point. There is a little arm on the margin that hangs down and trips the bell, make sure it is also moving freely.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Sep 07, 2009
How do I change the left margin on this typewriter?
There are two levers at the back of the carriage with a small arrow mark on them. You normally depress them and slide. A bell rings when the carriage approaches the right margin.
Using typewriter
Oympia SM3 deluxe italic manual typewriter
Apr 17, 2016 | Office Equipment & Supplies
I would like to trouble shoot my machine
Needs cleaning spray with WD40 in the slots where the keys are connected
Nov 05, 2015 | Royal 1949 Vintage Kmg Manual Typewriter...
How do I set or change the margins on my Royal Safari typewriter?
If you are following user's manual instructions to reset the margin and can't, maybe your Royal Safari is defective? Insist trying and if still no luck try to ge a typwriter repairman, a species in near extintion by now.
Jul 02, 2015 | Royal Office Equipment & Supplies
How can I disable the bell that rings (at various times) when I'm typing? I'd rather not simply move it, but turn the bell off altogether. It's driving me crazy!! Thanks. Claire
Space all the way to the right, press R. mar key to move the margin. however if it beeps a various times it is more likely the spell check CODE "1" will turn it off.
DickyO
May 10, 2011 | Lexmark Wheelwriter 1000 Typewriter
I can only type a few inches into a sentence before my Royal typewriter dings and stops typing for that line? how do i fix the timing?
At the top of the typewriter behind the platen (the big black rubber roller you roll the paper into) there is a scale with two push buttons on it. The buttons are the margins. The button on the right is the one stopping you. Push it down and slide it to the right to set your new stopping place...or all the way to the right to not have any margin at all.
Apr 08, 2010 | Royal MS 25 Typewriter
How to set margins
after hitting the return key, the carrier goes all the way to the left margin. If you need the margin to move even more to the left, hit the margin rel key and backspace to the desired position and hit the mar left key. Same for the right margin, use the space bar to move the carrier all the way to the right margin and press the margin rel and move the carrier to the desired position and press the mar right key.
Jan 27, 2010 | Royal Satellite 40 Typewriter
Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
Sep 05, 2009 | Office Equipment & Supplies
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
Margin clearing and resetting
You cannot "clear" the margins. You have a left margin and right margin. They MUST be set somewhere even if they are set at the extreme left and right of the carriage. This part is IMPORTANT!!! Some functions (like right margin or margin release) may be written in a different color or shade. If they are, you must hold down the CODE or FUNCTION key while touching that function. In any case, the CODE key or similar will be the same color as the function you are trying to access. Get the printer where you want the margin to be. If you want the left margin set to the left of the current margin you will have use the MARGIN RELEASE key first. This may be labeled MREL or MAR REL or something similar. Backspace to where you want the margin to be then press the LMAR or LEFT MARGIN key. That will set the left margin at that point. Repeat the process for the right margin. Hope that helps Ed
May 26, 2007 | Nakajima AE-830 Typewriter
165 people viewed this question
k24674
jasbo
jasbo
