Question about Panasonic CT-32HXC43 32" TV
TV will not turn on.
I turned off the TV at night, next morning it would not come back on. I went and bought a 6.3 amp 250 volt fuse after reading about it here. The fuse is kind of hard to get to. There is a little panel that has one phillips screw holding the cord in place. If you remove that and use a flashlight you can see the fuse to the left of the cord connection in the board. I was very careful trying to get it out because I did not want to drop it. When I was reinstalling the fuse I decided to make the hole larger, there was nothing behind it to hurt. This made the job a lot easier. You can either glue the piece back in or leave it off.
  • amcolvin Sep 06, 2009
    For your information DIY hater I epoxied the small piece back on that I had removed. You are blowing this thing way out of proportion. I simply replaced the fuse. Taking the back off is not an easy job and why would I to just replace the fuse. If the fuse would have blown I would have taken it in to see if it was worth repairing.
    Problem Solver:
  • 11 Answers
This is exactly the kind of thing that could get a professional servicer in deep liability trouble if he or she returned it to a customer. If you lose that piece and ever need the set serviced to find out why that fuse blew again, they should not release it to you without an entire cabinet back. The set was made to be serviced by removing the back, not cutting it apart. Curious little hands can find their way into dangerous electricity that should not be available to them. This applies even if there are no toddlers around, what if the set is sold and the buyer has no idea of the danger?
Posted on Sep 05, 2009
  • DIY hater Sep 07, 2009
    What troubled me was your statement "You can either glue the piece back in or leave it off."
    Leaving it off is a bad suggestion, that's all.
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Hi My wife was watching our 2002 Panasonic CT36SX12CF model t.v last night, all of a sudden there was a pop noise and the screen went black. The tv would not turn on again. Any ideas what the problem...
hey Al more than likelly it was the fuse that popped if you take the back panel off the fuse is next to the power cord and should take a 6.3 amp 125-250 volt fuse
Oct 31, 2010 | Panasonic CT-36SX12 36" TV
Turned TV off, went to turn it back on the next night and nothing
yes it could because if you did somthing to the fuse it could cause this problem
May 19, 2009 | Microsoft Xbox 360 Console
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Sony kv-32hs500
Most probably the IC504 (Sharp PQ05RD21) on A-Board went bad. This model TV, including mine, is notorious for having this problem. The IC is rather easy to find and inexpensive (around $2.50). Your main problem will be desoldering the old one and soldering the new one.
Good Luck.
Jul 25, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
My tv acts as though it is not plugged in
not mutch you can do,savety circuit has tripped the set.
needs a repair person.
horst in wollongong
Mar 26, 2008 | Panasonic CT-32SL13 32" TV
Will not turn back on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Feb 12, 2008 | Pioneer SD-P50A3Q 50" Rear Projection...
No power
Do what I am going to do. Take it back. Mine is only a day old.
Jul 31, 2007 | iLO V27DMBX Television
Will not turn on, but....
the arc when you plug it in is from the degause cirt operating, the fault sounds like at least a pwr supply repair $100, & or vertical + $50,and or horizontal + $150,If water is the reason.
Dec 06, 2006 | RCA 27F650T 27" TV
Pioneersd533hd5
Had the exact problem on 11/14/06. Ordered a power supply board, which was $300+, got it in and when I went to replace the part, found that the old part had a blown fuse (a lot cheaper). Of course if I had put in the new part it would have fixed it also. CHECK THE FUSES IN THE MIDDLE CIRCUIT BOARD (there are 3 boards).
Nov 10, 2006 | Pioneer SD-533HD5 53" Rear Projection HDTV
Panasonic CT-32HXC43 32" TV Logo
118 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
