Question about NEC ND-6500A DVD±RW Dual Layer Burner
DOES NOT BURN DVD; AT END OF BURN "ERROR" MESSAGE W/ NO INFO
THIS IS MY FIRST ATTEMPT AT MAKING A DVD FOR TV VIEWING: HAVE TRIED 5 TIMES WITH NO RESULTS. I FEEL SILLY ASKING, BUT...
DOES THE NEC DVD=RW ND-6500A ACTUALLY "BURN" DVD'S ?
I AM A BETTER THAN AVERAGE PHOTOSHOP USER OF ORGANIZER AND ELEMENTS; AFTER MAKING A SLIDE SHOW, THEN INTO A MWV AND WORKING ON IT AS A "MOVIE" IN ELEMENTS WITH TEMPLATE, MENU, SCENES ETC. I AM UNABLE TO MAKE A DVD OF THAT PROJECT,
WHEN ATTEMPTING TO BURN ON A DVD AND ALLOWING FOR
1. PROPER SIZE TO FIT ON DVD+R
2. APPROPRIATE QUALITY LEVEL TO NOT EVEN COME CLOSE TO THE LIMITS OF THE DISC
THE DVD DRIVER WORKS FOR AN HOUR (OR MOVE DEPENDING UPON THE LENGTH OF THE PROJECT INVOLVED), FINISHES THE PROGRESS AND EJECTS TO HAVE A BLANK DVD AND "ERROR" MESSAGE. I HAVE TRIED EVERYTHING THAT I CAN LOGICALLY ATTEMPT WITH MY GIVEN EXPERIENCE...IS THERE ANYONE OUT THERE WHO CAN HELP, EXPLAIN, CLARIFY.
    President:
  • 1,015 Answers
I see that you are using a DVD+R disc...Some drives can only do + or -. Have you tried using a DVD-R disc? You could also check and see if there is a firmware update from the NEC website.
Posted on Sep 05, 2009
Testimonial: "Thank you for your suggestions. It is a good start in trying to solve my problem. I will start with the "update" aspect; no DVD- at this time.Thanks S"
  • 509 Answers
I've always had better luck with DVD-R than DVD+R. Make sure that you're saving it to a correct format. You want to save it to an NTSC 720 x 480 setting (MPEG 2) and Not MPEG4. After you save the file, you might need to use a separate program like NERO to actually burn the DVD for you. What format does it save your file as? Is it an ".ISO" or ".WMV" or ".AVI" or what format, or suffix does the file have? Videos are pretty tricky. I would also try to use the slower burning speed, like burn at 8x instead of 16x. I would go to "settings" or "options" and see what your options are for how you're going to save your file. Good luck and report back and I'll try and help you somemore.
ADCV 110 converted handy cam tape and burned to DVD RW, when played back on a Sony DVD player, get error message "no audio, no video". Tried all combinations and get same error. Can view DVD on my PC just...
DVD RW is a reusable dvd that most home entertainment systems cant read because most times the disc is not properly finalised your pc is another matter,
my advice is that you should burn the movie onto a DVD-R and that should do the trick,
Aug 01, 2010 | Televison & Video
Error message when attempting to create a DVD
Try to burn your programs using a different burning software like nero or etc.
Nov 08, 2009 | Microsoft Windows XP Media Center Edition...
Failed to burn DV disc.Cyberlink Media Show error code 0x0A180001
I was also suffering this problem with Nero 6. To solve your Problem first make sure that the windows you are using that supports your Software if supports, then your Optical Drive may not Write in high speed 16x or 18x, write your files in DVD in little bit slow speed, after doing all this if it gives same problem then Please reinstall your windows you are using.
Mar 08, 2009 | Computers & Internet
Error Code: FF052102
SOLUTION FOR THIS ERROR: FF052102
Dec 25, 2008 | JVC Everio GZ-MG130 Camcorder
Dvd cd rom drive reads code 10 on Satellite A205-S5825 laptop
http://support.microsoft.com/kb/310123 check error code 10:
1. update the driver: go the toshiba website, go to support, provide system info and look for knowledge base info related to your problem and also look for possible driver updates - post the model of your laptop and we'll help getting the page for ya!
2. http://support.microsoft.com/kb/943104/
make sure the device is enabled in windows and in the bios.
also disable any advance features (check with toshiba if you have any.. .and make sure your driver is updated before), lastly play around with the settings (make sure the driver is updated before doing this)
and remember to try one thing at a time, test, then move on to try something else.. be patient and methodic.
post back with your findings!!
Dec 06, 2008 | Gateway 700 XL PC Desktop
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Humax Tivo will not record to DVD
After the update to 1.15 I had to delete EVERY recording on the unit. After that, any new recordings would burn just fine. However, some have found that same failure even after a hard reboot (repower). Called Humax level-1 support and they suggested a replacement unit so I swapped it out. But I've since learned that TiVo "pushes" a DVD firmware patch (possible supplied by Humax) from 1.08 to 1.15 and that patch is the culprit. That patch is suppose to make the DVD burn at a higher spin rate. After talking with level-2 Humax support they heard of the problem and said "the unit is working as designed", meaning, the DVD drive manufacturer specs say the drive is capable of a faster burn rate. So now I have Humax DTR800 #2 and so-far-so-good, but TiVo hasn't pushed the patch onto the box yet!
Nov 10, 2007 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
Burning trouble
the lens of your dvd writer might not be working properly anymore, i strongly recommend that you replace your writer with a new one.
Sep 03, 2007 | Samsung (DXP47810JL) 5 Pack 8x DVD+R...
NEC ND-6500A DVD±RW Dual Layer Burner Logo
271 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
