When switched on it clicks on and off ..i have to unplug and power on several times before it will start up...i can hear a high pitched sound in between the clicking sounds....once the tv powers on itfuntions normally....
  • 1 more comment
  • cabo2020 Sep 05, 2009
    it is a samsung model #
    HCM5525W
    are these capacitors on the power board...if so which is the power board
  • cabo2020 Sep 06, 2009
    hcm5525w is the model # on the manufacturing label on back of the set
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
HCM5525W is model number?This set is a rear projection crt type set and does not have a color wheel---have you looked for Glycol leaks on all the circuit boards?
Posted on Sep 06, 2009
  • SD Tech
    SD Tech Sep 06, 2009
    Confirm actual model number to me that is on back of TV set?
  • 10,594 Answers
NOTE:- TV repair is qualified tech job because there is electric shock risk involve. Be careful if you are repairing TV. Unplug TV from wall socket for few hours before to open it back cover.
Symptom shows there are few electrolytic capacitors in power supply board that are weak / leaky and needs to be replaced.
You need to inspect physically these capacitors as their top would be bulged or you will see liquid on bottom of capacitor cylinder.
Replace these capacitors with same value that is written on them.
Thanks.
Posted on Sep 05, 2009
  • Shahid Electronics
    Shahid Electronics Sep 06, 2009
    Follow AC cord of TV that will take you to power supply board.
    Thanks.
    Brigadier General:
  • 4,090 Answers
This is a faulty solenoid, Much like the starter switch in a fluro tube.
It will need to be replaced, preferably by a technician as there are usually other small componenents that also are involved.
  • 3,230 Answers
Well it sounds like an internal power supply fault or convergence ICs are bad and some low ohm resistors and or low amp fuses with some cold solder connections.
post back the model number of your TV for more information...
Thanks
  • Mukesh Kumar Sep 05, 2009
    Most likely it's a power supply failer.
How do you tell if the starter has gone out?
Well....the car doesn't start. If you turn the key and you only hear a click,click, click it is the most common sign it is out. If you try to start and it sounds like a high pitched spinning then it could be out or you could have a bald spot on your fly wheel. That is a more expensive problem
Feb 07, 2016 | Cars & Trucks
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
When I went to turn on my 20 month old 46in LCD LN46A500 it made the loudest high pitch screeching sound that no one would like to hear and the picture was black. The remote buttons and the TV control...
The power supply board have fail badly,all that high pitch screeching sound,it came from those high voltages gaps from those tranformers,that giving ur tv high voltages.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Samsung LN46A500 46 in. TV
Rca 27410tyx1 will not shut off
Sounds like trouble in the standby/power up circuit. have you tried unplugging the TV for a half hour and seeing what happens? It might start up but I think this problem won't go away. If you heard a high pitched buzzing it sounds like a problem in the high voltage not letting the start up circuit work. threy are related. The start up circuit waits for the high voltage to stablize and then switches it on.
Sep 16, 2008 | RCA TruFlat 27F520T 27" TV
Mother board problem
The noise must be coming from the power supply. The only thing running before you press the power on button is the PSU.
Unplug the power cord on the PSU. Check the back of the PSU for a red slide switch. Make sure it is set for 115v. Than disconnect the main power from the motherboard. Plud in the power cord, (still hear the high pitch noise?). Swap out your power supply.
Mike
Apr 09, 2008 | ECS RS400-A (V1.0) Motherboard
Television won't power up
It sounds like the high voltage circuit got damp and arced. This arc caused the horizontal output transistor to short.
You might try replacing the output transistor if you're experienced in this type of repair. If not then you need to take it to a repair shop.
The "whistle " you're hearing is the power supply indicating that it has a short on its load. When the power supply has an over load (short) its frequency drops down when your ear can hear it oscillating. This type of power supply is a switching power supply normally operating a several thousand hz(cycles) which is out of range of human hearing.
Stargazer
Mar 15, 2008 | Televison & Video
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
