Question about Cameras
Everytime i insert my sd card into my vivicam 5399 it freezes?
  • 47 Answers
Tried formating the card ??? plug the vivicam with the sd card into ur pc with the unit turned off when it comes up in "my computer" right click the E: or F: drive and format
Posted on Sep 05, 2009
Never insert the card into the camera with the power on or plugged into you computer (USB port provides power to the beastie)
Posted on Nov 05, 2009
SD Card states error card when inserting and turning it on.
you need to go into the settings on the camera and ask it to format
May 30, 2013 | Vivitar Cameras
I have a vivicam 7025, when i insert the SD card says card inserted but then says its going back to internal memory so i cant take no pictures
I also have a vivicam 7025, with the same problem, when I insert the SD card, first it recognises that a card has been inserted but then it says its going back to internal memory. I can't take any photo's and am VERY frustrated!!! Did you find out how to sort yours out?
Dec 21, 2010 | Vivitar Cameras
Cannot download from vivicam 5399 NO DRIVER FOUND
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Oct 30, 2010 | Vivitar 5399 Digital Camera
Vivitar 5399 not reading memory card. Originally had a 4GB card and that worked fine, then all of a sudden the camera wouldn't read the memory card. Card is fine in other cameras. Just switched to a...
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Aug 28, 2010 | Vivitar Vivacam 5399 Digital Camera
Put sd card in vivitar 5399 but not reading it
Receiving no response in over a month, I assume this is no longer a problem.
May 28, 2010 | Vivitar Vivacam 5399 Digital Camera
Won't read memory card
This usually indicates that you are trying to use 'newer' SDHC High Capacity cards of 4GB or more. Older and cheaper units like this Vivicam 5024 unfortunately may be limited to 2Gb 'standard' SD cards.
Hope it helps: let me know what cards you are trying to use.
Jan 16, 2010 | Vivitar ViviCam 5024 Digital Camera
I just inserted 4GB Memory card and took only one picture. I keep getting error message "Memory card is full, insert a SD Memory Card to Transfer and take more photos".
http://www.vivitar.com/products/19/ViviCam%205018%20User%20Manual.pdf
Is the manual, and you need to refer to pages 6 and 7.
If you still have problems, you should contact Vivitar support. This should not be a problem since the camera automatically switches to the SD card when inserted.
Jan 10, 2010 | Vivitar ViviCam 5018 Digital Camera
I have a vivicam 5399 which is not showing pictures on the screen
I just had the same problem. The LCD screen or onboard computer had gone bad. Nothing I could do but send it in to be repaired
Sep 24, 2009 | Vivitar ViviCam 5385 Digital Camera
ViviCam 8025, not recognizing SD
take out the battery, then insert the sd card until it clicks in and stays. Then replace the battery. This should work.
Jun 28, 2009 | Vivitar ViviCam-X30 Digital Camera
Problem when inserting sd card
the reason is with phones you must insert and remove the card while the phone is physically turned off. some phones work anyway if you don't turn them off, but this is a fail-safe method that also ensures that you don't loose any information.
Nov 20, 2008 | Cell Phones
Cameras Logo
93 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
