Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Brush won't spin
My neighbor gave me this vaccum and the brush doesn't spin. Could this be a belt?
  • thenoticer Dec 08, 2007
    I managed to take the cover off and clean well. They have dog and there was so much dog hair clogged in it, once I freed all that it seems to be working fine.
    Thanks.
  • rosbach723 May 23, 2008
    I can move the roller by hand, but it does not move when turned on.
I tightened the phillips sdjustment screw near the belts and it fixed the problem
Posted on Dec 17, 2007
    Problem Solver:
  • 9 Answers
Yes it could be the belt or the "Bearing Assembly". I had the same problem with a vacuum I got from a friend. 1st I replace the belt,but when I turned the vacuum on I could smell something burning and then the belt broke in half. I then realized the brush roller was stuck in place and would not turn even with force applied. I later found out that 1 of the 2 Bearing Assembly's was worn out,when a Bearing Assembly is worn out the brush roller can not spin. So now it looks like I need to buy a whole new brush roller,unless I can find a place that sells the Bearing Assembly for part number 61445-1,which is a roller brush for a GE Wal Mart vacuum.
Posted on Dec 08, 2007
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
My bissell vaccum doesnt work even though i've replaced the belt but when ever i turn it on i get this rubber smell...can anyone tell me
Sounds like the beater brush that the belt controls is frozen in place and needs to be cleaned. Remove the brush and clean any debris that you find on it AND at either end. The end pcs are used to hold the ends of the brush stationary while it spins via the belt. When you get the brush off, spray both end pcs with a bit of WD40 and work by hand until they spin freely. This should solve your problem.
Sep 12, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Eats belts immediately
HI There,
Usually when the belt breaks immediately, this indicates that your roller brush has gone bad and needs to be replaced. I have never seen the motor shaft being damaged and causing belts to break before. When the roller brush can't spin because it's bearings have worn out, the motor shaft continues to try and turn the belt, but since the belt can't spin the motor shaft at that point burns right through the belt.
To make sure that it's your roller brush, remove the brush from the vacuum cleaner, and hold it using just your two pointer finger tips, holding just the bearings caps at the end of the bar, and not the bar itself.
Try to spin the brush using your thumbs. Does the brush spin freely without resistance? It should spin completely around 3-4 times on each spin. If it doesn't spin, then your bar is bad.
If the brush doesn spin, and it continues to break belts, this means that the belt is being installed incorrectly, and is being pinched by the roller brush. Pull the belt forwards after installing to make sure the brush spins freely.
Hope this helped you,
Chris Jones
GoVacuum.com
May 01, 2010 | Dirt Devil M086355 Bagged Upright Vacuum
The main brush will not spin
I would guess the belt is broken. That happens often. Get a correct belt. Remove the brush roller. Wrap the belt around the roller and drive peg. Reasemble -- easier said than done, but keep trying.
Sep 27, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Twirly thing under the vacuum has stopped spinning
there is a belt that drives the beater brush. flip the unit over, you can remove the bottom cover by removing a couple of screws. to one side of the brush you will see a channel where the belt should be. go to you local walmart, sears or hardware store and in the vaccume section they will have belts, on each bag of belts will be a list of vaccumes that belt fits simply find yours. with the new belt simply lift the beater brush out at the belt channel side and install the belt around motor shaft and brush. then place brush back in place , be suer brush guides are in properly. this should do ya.
Aug 18, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
Jun 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vibrates very loudly when brush starts spinning
take out screws on bottom and see if tension bar can be tightened, make sure the right belt is in there, also if belt looks worn or gouged replace with a new belt
Apr 23, 2009 | Vacuums
Brush will not spin any longer
If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
Hoover Empower Widepath, brush won't spin.
The belt needs to be changed, it's probably spinning in place which is causing the smell (burnt rubber).
Dec 04, 2008 | Sandia Plastics Super Hipster Power Hepa...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
213 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
