How to replace the tention idler pulley
using a breaker bar or some other tool w/ 1/2'' drive, insert into idler, there is a square hole, remove belt tension, donot remove belt, but lift belt off say the alternator, it would help if you hang the belt w/ wire or something so as not to let it drop. using a 15mm wrench, remove mounting bolt to idler, remove idler. better to replace the entire ilder w/ pulley, as an assymbly, they wear out like any thing else. when istalling new idler, must be positioned correctly. theres a finger which protrudes out of idler, this must be inserted @ engine sideof idler. reinstall bolt, tighten, reposition belt, using breaker bar 1/2" drive again, remove belt tension, so you can get belt over alternator pulley, release tension , done ! make sure belt is centered, and on properly according to belt rounting. when satisfied w/installation , start engine, check your work, remember to visulize existing idler, etc., etc., before you start this so you can put on the new one on exactly the way the old one was !!!!!!!!!!1
need a model and brand for specific instructions
