Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirpool calypso start wash and 5 min later LD errors get to the screen
    President:
  • 1,776 Answers
The fault code "LD" indicates "long drain" condition. It's not only if the water drained, but how fast it drained. Check the drain line for kinks or obstructions. Check the pump. Remove the hoses and use a flashlight to look into the suction port. Make sure nothing is clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller spins freely. If there are broken/missing blades or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or a jammed impeller. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 07, 2009
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Washer stops when Ld comes up on display before final spin, but washer drains fine.
ld flashes if it takes longer than 5 min to pump out water to the point where the operating pressure switch resets.check the drain line for kinks,check drain for blockage,check pump operation.
Jan 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Whirpool cabrio error ld
Hi
Error ld means Long drain. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display.
If it doesn't clear the error then check whether your drain is kinked or clogged with lint and debris. If not then there is definetly some problem with your drain filter and/or drain pump.
Please do rate the solution as FixYa and Revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | Whirlpool Washing Machines
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Mar 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
On my whirpool washer LD light lights up and many times drain cyc
ld stand for long drain there is something in your pump or your drain most likely the pump you need to clean the pump or maybe even replace it if need be
Dec 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
LD.;....................
LD= Long drain if the unit has taken more than 5 min to drain out the water this code appears.. you eiter have a pump issue or a pressure switch issue.. does all the water go out of the unit??
Feb 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
137 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
