Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
I recorded onto DVD-R discs and then finalized but they wont play on my dvd? how can i get them to play ? i usually buy DVD RW
    President:
  • 1,015 Answers
Some dvd players cannot play certain types of discs. You could check to see if the manufacturer of the dvd player has a firmware update to fix this problem. Older dvd players have trouble playing some of these discs. Most newer dvd players do not have issues and have upgradable firmware to adjust for different formats. Does your burner also do DVD+R discs? Maybe try using those and see if it plays on your dvd player.
Posted on Sep 05, 2009
Can DVD'S be fixed to play on any dvd player?
,THATS GOOD NEWS. cheers,,. u don't mention what recorder u r using when u put the tdk-R IN,,, DOES IT TELL U TO format the disc ???????? if it does and u don't format it will not record on disc Hi again if u wa?t to use RW rewritable disc's then u don't have to finalize them to play on other DVD players u can buy rw disc's on ON. E/EBAY Cheers.,..,..,...., try another brand of disc like TDK .THEY R GOOD ..when u have recorded a movie go into youre menu and find FINALIZE ..when u have finalized the disc it will play on most dvd players good luck
Oct 19, 2015 | Televison & Video
My Magnavox Digital Disc Recorder & Video Cassette Recorder will not play DVD-RW discs. How can I solve this problem or get a replacement unit.
It claims to play -RWs finalized in DVD-VIDEO format, not VR. If a disc is recorded/finalized on a different recorder, not all players can play it. This is the price we pay for the convenience of the digital system.
Feb 11, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
CAN RECORD FROM VCR TO DVD+R, CAN PLAY DVD ON SAME, BUT CANNOT PLAY ON OTHER DISC PLAYERS. I THINK THAT THIS IS BECAUSE I AM NOT FINALIZING CORRECTLY. WHEN AND HOW DO I FINALIZE A NEWLY RECORDED DISC?...
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
Jul 09, 2010 | Philips Magnavox DVD/VCR Dual Player
I have recorded onto a DVD RW disc and finalised. It plays ok in the DVD i used to record - will not play in a computer or another DVD player?
You don't need to finalize the DVD+/-RW media DVD to work on other players this is only required for DVD+/-R media types.
It could also be the Brand that you are using I recommend SONY or PHILIPS
Jan 27, 2010 | Televison & Video
My disc records fine, plays great on the Magnavox, but no other player can read the disc?
You must finalize a disc before it can play on other machines. Please refer to your documentation for how to finalize a disc.
Jan 11, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Anything I have recorded onto DVD from TV wont play on any other machines. It will only play on this machine I recorded on. It is the same make and model mentioned here.
If you're not using DVD+RW blanks (VERBATIM work fine), then try them. DVD-RW blanks will not play on any machine but the one that recorded the disk (according to the manual.)
Nov 24, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recorded DVD will not play in another player
try playing on computer. if ok copy on hard drive and burn it. if it wont work on your computer. there was an error in the making of the disk..
Apr 15, 2009 | Televison & Video
DVD PLAYS CD'S BUT WONT PLAY DVD'S
Aquarius0128 there are two things to consider here.. dvd's recorded on a computer need to be closed/finalized after you have recorded onto them in order to be used on a stand alone player.. they will play ok on original recorder because of the design of these machines finalizing prepares the structure of the disc so it can be recognised by other players as a dvd video disc.. you will usually see a 'finalize disc' option in your recording program
Second issue is this.. even if finalized an older (or even some modern) stand alone players will not recognise a recorded disc made on a computer or even if it can there are different formats DVD+R DVD-R and even DVD-RAM and DVD-RW (the two latter ones are rarely recognised outside a computer)
Jan 29, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
172 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
