Question about Nokia 6600
I want to use micro sd card using with adapter in nokia 6600,but it is not work,some time memory card give option memory card will be currupted,when i formatted the card its reply card will be format,but phone show same problem again.and card is not opened.please give me reply........
    President:
  • Nokia Master
  • 511 Answers
Try to format the micro sd card from mobile it will take time but do it ..
Posted on Sep 06, 2009
  • Jaiwintata Jun 04, 2011
    My handset is nokia 6600. I try to inserted a kingston sd adapter to my handset. It correct good. I am inserting a 2gb sd in adapter and insert adaper the mmc port. And i am check memory, i have get an reply that 'no memory card inserted'.What reason of this. Please help me...
    New Friend:
    Problem Solver:
  • 6 Answers
Please insert a 1gb or 128 mb memory card in your adapter
Posted on Nov 24, 2013
Unlock memory card
to can put the micro card into a adapter card that you use to put your phone info onto your computer and there is a switch on the left side of the adapter put it into the unlocked position which I believe is up and then take out ur micro card it should be unlocked. I know Kodak SD cards have this feature with the adapter I unlocked my micro card this way
Jul 27, 2013 | Nokia C2-01 3G Mobile Phone Bluetooth...
Tip
How to unlock /removed password in your memory card
hi,
most of the time we are putting a password in our memory card so that the others cannot view the important and sometimes the confidential files..but unfortunately we forget it so what we are going to do if we cannot open our memory card?if we are going to a cellphone shop we are spending much money ,if we buy a new one we also spend ...
i want to share how to unlock/ removed password in your memory card micro sd...this is applicable only for the card like MINI SD(this is bigger than micro sd and used in nokia phone like n73 ,n80 ) and for MICRO SD (used in nokia E-series ,classic nokia like 3500c ,6300 ,3110c ,7210c etc and other chinaphone )...
tools you need is high end phone like nokia 5800 ,n95 ,e63 ,e71 etc...(for phone using mini sd like n73
you need an adaptor..
here is how..
1. insert your micro sd at nokia 5800 , memory card password will appear just cancel it..
2. go to menu,applications then file manager then you will see that memory card is locked..
3.open memory card you will see memory card locked
4. press options >memory card options and format memory card will appear
5. wait until formatting is finished
6.you will now rename the memory card and the password is gone...
note: in this process all your data will be lost but but you have no choice because no other way to
removed your password than this...
i hope it will help you ,thanks for trusting fixya
on Feb 09, 2011 | Cell Phones
I have black jack..and wen ever i insert my 1gb micro sd,,it shows storage card not found,,,,so,can you just tel me the way to solve this issue....
Dear,
try inserting a different micro sd card of 1gb in your mobile, if it gets work, then you could be sure that their is a fault in your that memory card which shows storage device not found.
it may got currupt.
or try formatting that memory card through a computer, then insert it..
it may will work, but if not then its time to buy a new memory card as that card is currupt.
regards!
Aug 18, 2011 | Samsung Blackjack SGH-I607 Smartphone
I bought a 2GB micro SD but it is write protected , what can i do please give me reply? Thanks
The adapter that you slide your micro SD card into to access it has a little slide lock on the side of it. 0-hxbuybsb-t555-1122-callout-s-.png
Unfortunately these adapters are notorious for going bad. There are other options you have to acess your data and that is to obtain a micro sd usb adapter. They are much more reliable. Let me know if this helps.
Jan 13, 2011 | SanDisk 2GB microSD Memory Card
Memory card unformatted nokia micro sd 512mb
my friend good day...the micro sd is not supported for nokia 6600 ,better use memory card which is the big one..thanks
Jun 09, 2010 | Nokia 6600
How to repair nokia 6600 if it is full memory
You can just delete some stuffs of it or get a micro sd card.
May 13, 2010 | Nokia 6600
How to remove password from micro SD card in nokia 5300
Hi there, I have a micro sd card from Nokia 5300 phone.But when i use the same card in Nokia 3120 Classic, the memory card has been locked but i did not set any password for the memory card...Can this issue be solved in nokia 3120 classic phone.Can the password be unlocked in nokia 3120 classic.........Please advise.....
max2010
Mar 10, 2010 | Nokia 5300 Grey Cellular Phone
The SD m2 2gb Micro does not work on my phone
the card shows sign of a rom ic being lost its firmware
Sep 05, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
MMC memory card is corrupted (1GB). does not format.
Please try to format the memory card using a memory card reader on computer and then insert the card back in phone, it will say corrupted again, but now you try again to format it from phone and it should work now,,.....
Nov 06, 2008 | Nokia 6600
Computer is not reading my Micro SD, but phone is reading..
What size is the SD card in GBs? If it is larger than 2GB (4 or 8) do you have a SDHC card reader?
Also try formating the card first in the phone and then using it. Using it straight out of the package, while able to be written, my have difficultly with other devices reading the data.
Jul 23, 2008 | PNY 2GB microSD Memory Card
Nokia 6600 Logo
474 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
