Question about Jandy Aqualink - Rs32 One Touch Pool / Spa Combination Control System
Can not get the spa to heat up although the led panel indicates heater is on and working
    Champion:
  • 246 Answers
Than the problem is at the heater check what code is flashing if any or get model and post
Posted on Sep 13, 2009
It tries to fire once and fails. heater service lite then comes on. The LED red lite on the Fenwl Box blinks 3 times indicating ignition lock out. What do we do to fix this problem?
Hot Tub Spa - Heater Troubleshooting Guide - PoolAndSpa ...
www.poolandspa.com/page596.htm
The World's Oldest & Largest Web Site For Swimming Pool & Hot Tub Spa .... close to the element, and the pump suddenly quits - it's dry fire time in just a minute or two. ...We think it's a safe bet to say that one of the major causes of heater failure ... It's much easier to describe what doesn't cause it than to attempt to explain ...
Spa and Pool Heating Problems - Swimming Pool Information
Jan 05, 2016 | Pool & Spa
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
How long should a 2007 eclipse spa take to heat up??
Usually spas heat approx 5 degrees an hour. If its been a day or so and your water isn't up to heat, you probably need a new heating element in your spa. Check the voltage at your heating element, and on your topside there is usually a heat indicator light that should be lit. If it has correct voltage at heater and the indicator light is lit, heater burned up. If you have incorrect voltage at heater check fuses for a possible blown fuse and see which pump it goes to, that could be your problem.
Mar 09, 2014 | Pool & Spa
Arcoaire unit. Heat will not come on. Has voltage to control panel from stat for heat. LED is not flashing but staying lit steady. nothing happens at all on heat. AC functions fully and properly.
Look on the units cover plate for a LED code, Determine what code it is indicating and follow the instructions, or post what the code is indicating.
Nov 04, 2013 | Goodman GDS80904BNA Open Flame Heater
LED panel on heater does not light up and water temp reads higher then actual 107/64 degrees on control panel
This is an indication of a bad water sensor. It also tells me that the pressure switch may be bad because if it is working then the light on the panel will light up telling you that the spa water is heating.
Rod
US Parts Center
Oct 20, 2013 | Pentair Pool & Spa
Sundance 605 Series spa. Recently had the motor replaced, but now the motor runs continually. Installer said I need a new board. Is there anything else that could cause this?
When a spa runs continually it can be a bad board but we would have you replace the Temp Sensor first. If the spa is not heating it could be the pressure switch is not working or it could be the Temp Sensor or the High Limit sensor.
Check the topside panel to see if the heat indicator light is on. If it is NOT on then your pressure switch needs to be changed.
If the Heat indicator light IS on then you probably just need a Sensor.
It is always possible that the heater relay on the circuit board is bad.
Rod
US Parts Center
888-521-6183
Mar 31, 2013 | Pool & Spa
Heater not heating
At first: is there any technician to learn and describe a problem in more detail? And what is this device model's name? Is there a POWER SUPPLY LED indication or not?
Mar 23, 2013 | Pool & Spa
My heater is heating to 100 degrees as indicated on the heater, but the actual temp in the spa is much less, usually 10- 15 degrees less
Press menu, scroll to settings. There should be a choice labeled "calibrate". You can change the temp reading here.
Mar 27, 2011 | Pentair Easy Touch Indoor Control Panel...
Sta-Rite Max-e-Therm pool heater -- cycling and HLS
make sure that you have adequate water flow going through the heater and that your water chemistry is balanced.
Jan 09, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Jandy Aqualink - Rs32 One Touch Pool / Spa Combination Control System Logo
100 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
