Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman 42'' mower when clutch-brake is engaged and released...the level does not return to original position which prevents mower from running at selected speed. my manual does not provide diagram of this assembly. any ideas?
  • 40 Answers
Seems that your clutch needs adjustment, no biggie here. Get your needle nose pliers and a spare ¼ inch bolt or pin. A small Philips screwdriver will also work. The needle nose pliers are for removing the cotter pin and the screwdriver (or bolt) will hold the brake lever in place while you make the adjustment. Then, check under the right side of the deck (side where the grass discharges) right under the plastic mat where your foot rests and next to the tractor's frame you will see the brake lever with the long spring attached. Have a helper move the brake/clutch pedal so you have a better idea of what's going on down there. Then:
1. Remove the cotter pin, washer, and brake spring from the
adjustable nut
2. Disconnect the adjustable nut from the brake lever assembly
and the parking brake latch.
3. Align the hole in the brake lever with the hole in the frame. Hold
the brake lever in place with your 1/4 inch pin, bolt or the screwdriver.
4. Pull the clutch rod forward until tight. Turn the adjustable nut
until the nut will fit through the hole in the brake lever.
5. Assemble the adjustable nut to the parking brake latch,
brake lever and brake spring. Fasten with the washer and
cotter pin.
6. Remove the 1/4 inch (6 mm) pin, bolt or scredriver.
That should return everything to normal. Assuming that there are no broken or bent parts in your clutch mechanism.
I hope you find this solution helpful. Please rate it and thanks for using Fixya. Good luck!
Posted on Nov 05, 2009
My lawn mower will start easily and continue running as long as the clutch brake is depressed but when I lift the clutch or try to engage the blades while the clutch is depressed the mower will stall.
This is a shot in the dark. I think you have a failed "operator presence safety switch". Rule this out by finding the switch and jumping it.
Your mower should run with no one in the seat IF THE PARKING BRAKE IS SET.
If the brake is released and no one is on it, it should shut off.
If you are on it and the brake is released you should be able to engage the blades (probably an electric clutch)
Purpose of this interlock is the shut the machine OFF should you fall off or jump off the machine. Do not disable this valuable safety feature.
Let me know what you find.
Thanks for your question @ FixYa.com
May 15, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Model 917.259566 Tractor starts perfectly, but stalls out when the clutch is released. Whats happening?
Most likely your seat safety switch is not working. In order for the engine to run with blade engaged, the operator present switch must be made when the brake is taken off (releasing clutch).
Oct 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Sep 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
ENGINE SHUTS OFF WHEN CLUTCH/BRAKE IS RELEASE OR WHEN BLADE IS ENGAGED
Your seat safety switch is bad or broken. Check the wire connecting to the switch and make sure they have not rubbed through anywhere.
Disconnect the switch and try running the mower again. If the switch is bad the mower will continue to run.
Good luck.
Let me know.
Regards,.
Aug 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
May 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
Mar 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
852 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
