Question about Water Heaters
We have a back boiler that fires up ok, but goes off after a couple of minutes. The pipes get hot around the cylinder & the 3 way valve. I have tried turning the stat on the wall to the highest setting. Hot water gets hot but none of the rads get hot. Any ideas? Guys Thanks
  • 32 Answers
Either the circulating pump is not working or the solenoid valves are not opening( not all systems have these valves).
Posted on Sep 05, 2009
Pressure gauge reading zero
Hello Mark
First of all turn on a hot water tap and keep it running whilst you check to see if your boiler is firing up, if it is not then try to restart it, you should hear the flame if its running, turn your tap off then just stand by the boiler for a few minutes to see if the pressure gauge starts to rise, if it doesn't rise you will never get any hot water, you will have to add some pressure to about 1 and a half on the dial, to do that is simply turn on the water valve in the bottom of your boiler and watch your pressure gauge rise to about 1 and a half then firmly turn it off again, it looks like a small tap like the one at the back of your washing machine pipe, it's ok you will hear the water rushing in, now with your gauge at about 1 and a half and your boiler running your water will get hot
Oct 23, 2012 | Water Heaters
I have a HEAT MAKER MARK II Boiler and it wouldn't fire up , I replaced the HOT SURFACE IGNITER (I took the amp reading and i got 3.9 amps,wich is normal) and the boiler still wouldn't fire up i check...
Check the flow switch. Small black box lower left hand side as you face the from of the unit. Try to jump the connection and then see if it fires up. If it does, replace your flow switch. The flow switch prevent the boiler from firing because it is not sensing the water moving through the pipes. The boiler won't fire if water is not moving through it.
Craig @ Aggie Plumbing & Service
Dec 16, 2010 | White Rodgers Water Heaters
I have a alpha cd32 boiler,and i keep having to top the water up within the boiler,so to get hot water and heating again.i have checked for water leaks and nothing is found,however i did check the outlet...
Pressure relief valve - replace
The internal seal gets bunged up with dirt & scale and then leaks water [pressure] to that outside pipe
To avoid draining the whole system, turn off the two central heating taps on the 3/4 pipes and then operate the valve manually and / or disconnect - only a small amount of water will escape / drip to below the boiler
Replace valve and fill as before.
If you think your system needs flushing out - now is a good time
Turn off mains electricity to boiler before starting work
Mar 07, 2010 | Watts 3/4 Pressure Relief Valve
Boiler recycling when in DHC mode and water alternates hot then cold, back to hot every few minutes. Could it be pressure / flow rate.
First check pressure over 1 bar ok then-
1. check flow - is it adequate - a little less than the cold tap ok then -
2. does the boiler initially fire up on low hot flow but alternate as u say
If answers are 1. no but 2. yes then check for a furred up secondary heat exchanger
if 1. yes but 2. no [that is the water not the heating] goes hot / cold and if the boiler goes out when the water goes to cold then it's the diverter valve, either to replace or if it is one which has a internal diaphragm-replace that
Nov 25, 2009 | Water Heaters
Heatslave diverter valve
clicking rads are due to pipe expansion when getting hot.
If the hot water [secondary circuit] gets hot and the boiler stays on [does not keep going on and off] even with a constant low water flow then the diverter should be ok.
there is a valve to prevent the primary circuit [central heating] [ CH] from sending water to the rads. this or its control may be at fault.
both the
Both the CH pipes to & from the boiler should have manual valves to turn off. do this then try the hot tap-full on. If the boiler goes into overheat mode and the overheat stat kicks in to turn the boiler off -- then :-
Check also the heat exchanger, it may be furred up especially if you are in a hard water area. It means taking it off and manually checking [pour water through] If you're lucky it will be just muck to be forced out with hose pipe pressure, if not a new one
Sep 06, 2009 | Water Heaters
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
No central heating back boiler
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire
I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn
or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off.
Note if no water in it DO NOT USE the back boiler
May 03, 2009 | Bosch & Power Vent Water Heater
Baxi combi boiler 80e safty thermostat light on
baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Oct 15, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Water Heaters Logo
29 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
