Question about Baldwin 0014.003 "S" Door Knocker, Polished Brass
My door knocker was dropped and the knocker broke off. I cannot even it back together,
    President:
  • 1,996 Answers
If you're looking for Baldwin, they're here.
If you're interested in repairing it, try getting some pc7 epoxy from your local hardware store. (see here) It's pretty amazing stuff. I use it to repair bronze scupltures. Give it 24 hours before you try knocking on it. Still, that's pretty hard use, and it there's any way to drill a pin into it that might help the repair.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 05, 2009
How do I close the door to my printer? It seems that one of the hinges is broken apart.
If it's broken, you can't get it back together and your prrinter won't work with "door" opem look for the sensor which indicates that door is open, stick it somehow so it should show door closed and used happily forever your printer. If this trick is not possible, no way, take your printer to an HP repair center and get installed a new door.
Aug 27, 2015 | HP Officejet 6310 All-In-One InkJet...
Power mirror switch knob broke off on 2003 trailblazer
I was told I needed a new module on drivers side - I took it out and took it apart and cleaned the contacts in it with a spray electrical component cleaner and put it back together and it works just as it did before - saved 200 dollars not replacing something that wasn't broken!
Mar 30, 2013 | 2003 Chevrolet TrailBlazer
I purchased a whirlpool dishwasher GU2475xtvy2 with interior controls on top of the door. Might seem like a silly question, however, do I have to install with the door & controls controls out from...
It is up to you as to where you fasten the dishwasher at...if you push it back too far then you will have to do the setting before you close it which is no problem... but if you want it out a bit then you can do that and you will have a hip knocker that you will always be cussing at...
heatman101
Apr 23, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Battery door replacement how to? The battery door on my Nikon Coolpix L5 doesn't stay closed anymore because a little piece broke off when I dropped the camera. I can get a new battery door cover but...
OK IT IS EASIER THAN IT APPEARS TO BE(DONT GET SCARED)#1 REMOVE BATTERIES AND MEMORY CARD AND STRAP(if you have one)#2REMOVE ALL THE SCREWS AROUND THE CAMERA(you will see 3 screws around the tri-pod mounting hole DONT REMOVE THE LONE SCREW THAT IS CLOSER TO THE LENS(AS IT IS NOT HOLDING ANYTHING BUT THE TRIPOD INSERT AND LEAVING IT IN WILL MAKE IT EASIER TO SNAP EVERYTYHING BACK TOGETHER.#3CARFULLY AND EVENLY PRY ON THE BODY TO REMOVE THE SCREEN SIDE.#4 NOW YOU WILL BE ABLE TO SEE THE SMALL CLIPS THAT HOLD THE LENS SIDE OF THE BODY CARFULLY SEPERATE FRONT BODY (* this will enable you to see the large head on the battery pin.) #5 WITH A THIN NEEDLE NOSE PLIERS PULL THE PIN OUT #6 LAY THE NEW COVER DOWN AS IF IT WAS CLOSED AND INSERT THE PIN BACK IN.#7 BEFORE YOU SNAP THE FRONT BOBY BACK IN BE SURE TO PUT THAT TINY RUBBER BATTERY PULL TAB BACK IN THEN CAREFULLY SNAP THE FRONT COVER INTO THE CHROME AND THEN THE BACK COVER. PUT SCREWS BACK AND YOUR DONE.
Jun 21, 2010 | Nikon COOLPIX L5 Digital Camera
Window regulator cable broke???
Here's a video that will show you how to replace the rear window regulator in that car.
Apr 03, 2010 | 2001 Chevrolet Impala
Media Card Door Broke
Some battery doors and other parts are available on Ebay.
If this is the right link...
Ebay list of doors for this camera.
Sep 01, 2009 | Olympus EVOLT E-300 Digital Camera
Power windows on all doors won't go up down even with new switch can you help me with this
well in the rubber in the door the wires had got pinched some how and were broke off so we wire connected them together and that solved the problem.
Jun 07, 2008 | 2001 Ford Taurus
Baldwin 0014.003 "S" Door Knocker, Polished Brass Logo
69 people viewed this question
Top Baldwin Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Baldwin Electrical Supply Expert? Answer questions, earn points and help others
