Question about Logitech Z-2300 Computer Speakers
Right speaker on the logitech z2300 sound system wont play.
I was listening to music today and realized it didnt sound the same checked both speakers and found out the right speaker had no sound coming out. i dont know what it is i move the wires around to see if its a port problem but nothing changes.... what should i do?
  • 5,603 Answers
Make sure the PAN control is centered in your mixer control panel.
Posted on Sep 05, 2009
Testimonial: "that wasnt the problem... called support but it turned out i forgot to check the jack in the back of the computer if it was securely fastened it wasnt"
Is only playing mono when listening to music
It sounds like an error in the wiring of the speakers. Check that very closely.
Mar 02, 2018 | Pioneer Vsx 826 K Av Receiver Black
Hi. Today I bought a 3 foot audio y-cable and an RCA (Phono) Female to RCA (Phoneo) Female cable so that I could hook up these two speakers that I have that belong to a predisian sound system (boom box)...
All you need to do is get a USB based sound adapter 16/32BIT MINIMUM to plug your speakers straight into your laptop with better sound. Many laptops will have limited sound OUTPUT which places large limitations on pushing sound through your nice speakers. You already know the problem is not the speakers or new cables, therefore you know that problem has been isolated to your laptop. You may also check the volume settings in the laptop to ensure your running the highest possible BIT or volume enhacement software. Let me know if this does the trick for you.
Jan 09, 2011 | HP Audio Players & Recorders
The speakers wil not play on the background and the center.
If you connected to a 5.1 surround card and checked and they are connected ok you can hear all the speakers when you play music, movies that are in 5.1 format only. If you want to hear also all of them if you listen to stereo movies/music you must set the sound card to emulate multi channel. Also the player you use to listen music/wath movies must be set to 5.1 and must accept Dolby Digital/ DTS decoding if your sound card doesn't(eg. VLC media player-has integrated DD and DTS decoding and codecs for all tipes/formats).
Oct 13, 2009 | Logitech X-530 Computer Speakers
Z-2300 Left Speaker and port dont work
did you try plugging in the other speaker into the yellow output. If you can hear music doing that then its only your left speaker that is the problem. Try tapping the faulty speaker into the palm of your hand while connected. There might be a faulty contact to the actual cone of the speaker. I had to open mine up because i had the same problem. It turned out that it was the wires that weren't making contact. I scrapped and moved them around connected the speaker and it worked. I hope that i made some sense out of this. good luck.
Sep 06, 2009 | Logitech Z-2300 Computer Speakers
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
Logitech x540 speakers- rear speakers distorted on matrix mode
I installed my soundcard which is the sound blaster SE audigy but when i try to test the sound i see that it does not sound separately.What i have to do to make them sound saperately when i'm testing it ?
Apr 16, 2008 | Logitech X-540 Computer Speakers
My right speaker from my z-2300 stop working.
sounds like a loose connection somewhere inside that particular speaker. You could open it up to check for a loose or separated solder joint. The safe option would be to return to place of purchase and exchange for a new set.
Apr 14, 2008 | Logitech Z-2300 Computer Speakers
My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Jan 29, 2008 | Apple Logitech Inc MM50 Portable Speakers...
Logitech Z-2300 Computer Speakers Logo
1,193 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
