Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
John Deere Mower Engine Issue
I have a Kohler Command 13 engine in a John Deere riding mower. It will start, but will run wide open. It will not throttle down at all, but will run roughly choked. What is the issue here?
    Problem Solver:
  • 7 Answers
HAVE YOU CHECKED THE CARB AT ALL? LOOK AT THE LINKAGE & MAKE SURE IT MOVES FREELY! IF CARB CHECKS OUT MAKE SURE GOVENER IS ADJUSTED RIGHT!!
Posted on Sep 10, 2009
John Deere L130 riding mower w/23hp Kohler Engine,
need carb rebuilt one problem may need valve job carb rebuild 80.00 valve job 100.00 per cylinder have to take in to shop for this
Sep 14, 2014 | Garden
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
if that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
Apr 21, 2014 | John Deere Garden
No spark to the plug Kohler 8hp lawnmower engine
Check ingition switch, check battery voltage 12-12 1/2 volts,check in run position same voltage, check in start position same voltage
We've check switch first. If not problem we've check the points for proper voltage and opening and closing.
Jan 17, 2012 | John Deere Garden
Engine revs wide open when starting
Check to see if the throttle shaft on the carburetor is actually moving (with engine off) Does it slow down when you move the throttle control on the dash?
Start it up and try moving the linkage on the governor shaft, if there is little or no resistance but the engine slows when you move it, most likely you have a broken governor gear inside the engine. Another possibility is that the screws that hold the throttle plate to the shaft have come loose and the plate is jammed in the throat of the carburetor
Sep 14, 2009 | Garden
Need to order engine parts for a c314h john deere riding mower
If there is no #'s you can call John Deere or go on there web site and should find some info.If you have the model of the tractor john deere can tell you what engine you have. If you have an engine # they can also help you.Good luck. donnyb60.
Mar 24, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
437 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
