Question about Kenmore 15864/15862 Top Load Washer
Kenmore top load washer wont spin/agitate.I replaced the coupler
Before this happened but previous problem was solved by replacing agitator dogs, now this.
    Problem Solver:
  • 18 Answers
This is either a coupler kit needing to be replaced or a transmission. You will see the broken coupler before you remove the transmission.
Posted on Sep 06, 2009
Kenmore washer wont agitate
i would look at your lid switch this could be faulty
Feb 23, 2010 | Kenmore 22422 Top Load Washer
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Kenmore Heavy Duty Washer 70 Series - agitation problem
Check out this video if the top just spins this is your problem and directions to repair it.
http://video.google.com/videosearch?hl=en&client=opera&rls=en&hs=Rfi&q=how%20to%20change%20whirlpool%20agitator%20dogs&um=1&ie=UTF-8&sa=N&tab=wv#
Sep 06, 2009 | Kenmore 22422 Top Load Washer
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Washer not spinning
Is the agitator not agitating or is the whole tub not spinning? Does it drain? Ill post a tutorial for replacing agitator dogs tomorrow. It will be posted under tutorials here. www.shop.washermd.com Dave
Jan 14, 2009 | Kenmore 24902 Top Load Washer
Kemore 90 Serieswashing machine fills and spins but won't agitate
Remove the agitator and see if the agitator shaft moves during agitate. If it moves then the agitator spline is worn or the agitator dogs are worn and the top half of the agitator will not work. If no results then the gearcase would have to be replaced
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Agitate/Spin Issues (again)
if your coupler is good change your agitator dogs that will fix slow wash and clutch on top of transmission or lid switch for no spin
Nov 05, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore top load will not spin
Under the agitator and beyond the dogs is the lower half of the of the agitator,remove and you will see a spindle surround by a drive block fastened to the tub with a nut,check for metal shavings and wear.
Aug 05, 2008 | Kenmore 22422 Top Load Washer
GE WPRB9220D Top Load Washer
There may be nothing wrong with the splie/gearbox shaft. At the top of the agitator on the inside is a brass "dog" That may be worn and you will need to replace it.
Oct 28, 2006 | GE WPRB9220D Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
127 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
