Question about LG VX8300 Cellular Phone
Cannot get any sound. Phone makes calls, but no sound is sent or received to the handset.
My uniden phone is not working. All hand sets say Check Tel Line. Will not make or receive calls. Will a dead battery in one handset make all handsets malfunction? Are batteries available?
batteries are available from e-bay
one dead battery will not affect any others
all hand sets make calls and receive calls through the base unit that is connected to the landline
base unit is connected to the landline and operates any hand set that is picked up
make sure all handsets have the end call button pressed as one not pressed after use may keep a line open
call your provider to check the land line to your premises
borrow a neighbours phone and plug it into the socket and see it you get a line on their phone
Oct 30, 2016 | Uniden Lands Phones
Good Morning. One of the handsets in my Uniden DSS7815+1 Cordless phone system fails to show any information at all, even though the handset can make and receive calls normally. The screen just sho
The circuitry has gone out in the phone, nothing more you can do, but replace it, might be able to find one on EBay, unless you can live with it that way.
Sep 27, 2017 | Uniden Lands Phones
I can hear callers through my s11 plantronics headset but after using and trying all configuration no.'s they can't hear me at all
Make sure the Plantronics S11 headset is plugged into your handset jack on your phone, not the headset jack, this will make a difference on most phones. After plugging the S11 into the handset jack on your phone, you will need to pick up your handset receiver and sit it off to the side of the phone to place a call or to receive a call, after you are finished with your call sit the handset receiver back in the cradle on your phone.
Good luck from Headsets Direct!
Nov 07, 2011 | Plantronics S11 Headset
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
Heavy Static on phones. Can't hear caller. No caller ID
Room monitoring mode is basically a type of Intercom.
Press the *TONE/exit button on the handset to exit room monitor mode.
I will provide you with link to the user manual of the phone. Have a check at it. Might be useful.
http://www.home-electronics.net/ge/pc/IB/28112EE1_IB.pdf
May 30, 2009 | GE 28112 Trio Cordless Phone
When I send a picture from my phone, it says it's sent, but the person I send it to never receives the picture.
For picture messaging there are a couple of things you and the other person needs...
1, A MMS capable phone, e.g a phone able to send and receive picture messages.
2, The correct MMS settings, both you and your friend needs settings for picture messaging, just like you need settings for going onto the net.
3, On some networks, the service has to actually be turned on by the network. e.g some networks who are behind dont have the service turned on for everyone you have to actually call them and make sure picture messaging is enabled on your account.
My first thing to check would be number 2, make sure you and your friend have the correct settings for sending and receiving picture messages, if they dont have the settings on there phone, even if your phone does then they will not receive the picture.
There are a couple of ways to get the settings.
1, You can search for the correct settings on the net for your network and make and model of handset and then manually enter them (slow)
2, Most decent manufacturers have an option on their website e.g Nokia, Sony Ericsson, to select your phone model, type in your phone number and network and have the settings sent directly to you.
3, You can call the network and get them to send the correct settings to your handset.
May 09, 2009 | Motorola Mobility MOTOROKR EM330 Cell...
When makeing or receiving a call, I can hear the other person, but they cannot hear me
Ensure that the handset is plugged in to the correct spot on the bottom of the phone. Flip the phone over and look.
It should be in the handset location NOT the headset... they look the same, and the phones handset will fit in the wrong spot on the set.
Apr 27, 2009 | NorStar T7316E Telephone
Handset problem
It sounds like you have a defective handset cord or handset. First, at your phone, switch your handset with another phones handset that you know for sure works. From your phone make a test call. If the caller can now hear you, the original handset from your phone is defective. If the caller still can not hear you, switch your handset cord with another handset cord from another phone that you know works. From your phone make another test call. If the caller can hear you, then your original handset cord is defective. You can purchase another handset cord from your local office supply store. Your phone uses a standard handset cord. It may be difficult to match the original color of your handset cord. Be sure to take your defective handset cord with you, so you can try to match the color. If the caller still does not hear you. Put your original handset and original handset cord back on your phone. Then plug your phone in to another wall jack, that you know works with another phone. The other phone needs to be an identical phone to yours (same number of buttons and same model number. The model number can be found under the phone). Wait approximately 90 seconds, sometimes longer, after you plug your phone into the other wall jack. Now, make another test call from your phone. If the caller can now hear you from your phone with it plugged into another working jack, then you have a defective station port or jack where your phone was originally plugged in at. If the caller still can not hear then you have a defective phone.
Nov 19, 2008 | NorStar M7208 Corded Phone
VOICE CANNOT BE HEARD WHILE MAKING / RECEIVING CALLS
have you replace the spiral cord of the handset? if you do may the handset is defective, try replacing the handset, if you have extra unit try to borrow and connect it to your phone just to see if its good or not.
Jun 21, 2008 | Panasonic KX-T7730 Corded Phone
Handset doesnt work
Do you have another phone (cell phone) you can use to make a test call to yourself? If you can answer a call and the Uniden transmits voice OK, then it is probably the speaker and may just be a bad solder connection. If the handset does not transmit or receive I seriously doubt you have a bad microphone AND a bad speaker, you'd be looking at something more serious.
Jul 25, 2007 | Uniden EXS 2080 Cordless Phone (EXS2080)
LG VX8300 Cellular Phone Logo
106 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
