Question about Vacuums
The brush on my bagless vacuum won't rotate. It
The brush on my bagless vacuum won't rotate. It also smells like rubber is burning
  • 10,865 Answers
If the brush doesnt rotate, the belt is either broken or stretched. If you have a Dyson, you will have to replace the entire assembly for about 80 dollars. Other brands you can simply replace the belt for about 5 dollars.
Posted on Sep 05, 2009
Eureka maxima vacuum smokes and smells like rubber burning..whats wrong with it..the brush turns but seems like its blowing outwards too
when you get a burning rubber smell, the drive belt is usually slipping on the motor due to friction on the brushes. Remove the belt and free all the tangled hair to allow the brushes to rotate very easily and then put a new belt on.
Jun 03, 2015 | Eureka Vacuums
Bisell 3750 bagless makes a burning rubber smell after about two minutes
The first place to look is the brush roller for hair or thread binding it. Put the machine on it's side and look at the underneath side towards the front. Th brush roller will be there. Take the cover off to expose the roller and see if there is something wound around it.
Good Luck,
Wayne
Aug 14, 2010 | Bissell 3750 Lift Off Bagless Upright...
Theres a burning smell of rubber and a flapping sound inside the hoover
Sounds like some object stuck in brush roller, causing belt to Burn, check / clear should cure....
Nov 19, 2009 | Dyson DCO7 Animal Bagless Upright Cyclonic...
Smoke coming from lower base of vacuum cleaner
Make sure everything is dried off, I encountered the same symptoms once when I had some water remaining in the rotating brush after wiping the machine down.
May 19, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Bissell lift off, brush won't move smell burning rubber belt fine
OK - so your brush roller is jammed. And yes, the belt is melting! Unplug the machine, remove the belt (you will need another new one anyway) then see if you can turn the roller by hand. If it turns freely without you doing anything else, then you may have put the new belt in incorrectly. However, you will probably find you can't turn it, or it's hard work (it should rotate freely). Remove the roller and check the bearings - there may well be something tangled up at one end of the roller. If you can get the roller rotating freely, all should be well.
Good luck
Mar 08, 2009 | Bissell 6595 Lift Off Bagless Upright...
Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Jan 19, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Belt is burning?
is the brush turning?  remove any debris that is keeping it from rotating.  It does sound like the belt is burning because the motor is trying to turn it and the brush/sweeper is jammed.
Oct 16, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Bissell Cleanwell II Bagless uprighht vacuum
Hi Pmob20,
Remove the brush and clean all the string or whatever may be trapped at the end edges of the brush.  This is usually the case with Bissel vacs, that string or fiber gets trapped at the ends of the brush assembly.
Oct 10, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Burning smell
Hi. What does the burning smell of? Is it 'rubbery', or is it acrid and 'chemically'?! The most common item to 'burn' is the belt which drives the rotating brush at the front. Does your cleaner have a belt? This would give a burning rubber smell. The instructions should explain how to change the belt - have a close look and see if the belt has been slipping on the motor spindle. If it has, then it'll probably be worn at this point and should be replaced. A common cause of this happening is the brush bar getting caught in something - edge or rug, etc - and being forced to a standstill. If the smell is more 'acrid', it could be a problem with the motor. This is a repair service job.
Sep 22, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Vacuums Logo
64 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
