Question about Amana SXD524VW Side by Side Refrigerator
I have an Amana bottom freezer frigerator. The
I have an Amana bottom freezer frigerator. The compressor attempts to kick on but won't. Could the capacitor or relay or what be wrong? Any help would be nice.
  • 220 Answers
Possibly a bad relay/overload or shorted run capacitor.If it was built between 2002 and 2005 it may be a bad compressor in which case you would want to check the warranty for possible coverage.
 the relay/overload and run capacitor plug right into the compressor on the left hand side.
 IF it isn't under warranty and the Oem part won't get it going pick up a 3in1 hard start for it they are easy to install and will get it working for you.
Posted on Sep 05, 2009
My fridge(& freezer) started giving off a bad burnt odor then stopped cooling (amana 25 cubic/mod #afd2535fes). any suggestions as to what it might be?
You said it stopped cooling, does the compressor kick on, or is it dead? Is the condenser fan operating (the one that blows across the condenser grill by the compressor)?
Is your condenser grill clean? What indications are you getting specifically?
Jul 15, 2011 | Amana 25" Cu Ft French Doors Bottom...
Someone left the freezer door open all day and now thats its closed nothing is freezing and I noticed the compressor is not kicking back on - just the fan is running.
Hey, it is possible compressor has been overloaded due to constant running, you could get access to it and have a look on the motor, all motors have overload protection, sometimes it can be a small button on the motor frame near where the power cable comes into it. It may even be located inside the terminal block for motor electrical connection. When attempting to fix anything electrical, you MUST ALWAYS unplug it and make sure it is dead.. Hope this may help. Matt.
May 22, 2011 | Amana ABB1921DEW (185 cu ft) Bottom...
My DRB1901C is not freezing. It's sounds like its trying to kick over for a few seconds then fails.
If neither cooler or freezer is working it sounds like the compressor is locked up. When that happens it tries to start and will hold the start capacitor in until it overheats the safety contacts. It will overheat in about 3 seconds and then kick out. This happens sometimes if the door is opened right after the compressor has turned off because it is cold enough in the cooler/freezer. However if this continues time after time and the compressor does not start, you probably need a new compressor. You may consider a new refrigerator, since compressor changeouts are fairly expensive.
Sep 21, 2010 | Amana DRB1901C Bottom Freezer Refrigerator
Where is the drain located in the amana refrigerator that empties the water into the bottom drain pan? ModelTC20E-L Amana frigerator
Good day,
In the freezer compartment, after you remove the rear panel, you will see the cooling (evaporator) coil. There is an aluminum pan directly below the coil. The drain hole would be obvious unless it is iced over, in which case you would need to melt the ice out.
It is connected to the drain hose which you can see by removing the back bottom cover of the machine that houses the compressor. If open and working properly, the hose carries the water to the drain pan which allowsit to evaporate.
If the freezer has an ice maker, it will have to be removed first. In addition any support brackets if they prevent the removal of the rear panel.
Jul 26, 2010 | Amana ARB8057CSL Bottom Freezer...
Amana BX21VW cool but not cold, compressor not working
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Sep 13, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Amana refrigerators is not staying cold and freezer is not freezing. Makes a "humming" sound, on and off, like a low "grind" noise, or like the noise an airconditioner makes prior to kicking on.
Mine had the same problem, and I had a tech out today who determined it's the motor inside the freezer. It's (the fan) not running. It's a $100 part, but if your refrigerator is new enough, it's probably worth the investment to go ahead and have it fixed.
Jul 29, 2009 | Amana ABB1927DE Bottom Freezer...
Amana bottom frezzer refrigerator
Gazzo, You are on the right track. I've been finding a lot of compressor failures on these Amana's. It's possible that the overload and relay for the compressor failed, but Im more inclined, from what I've seen, that the compressor is the problem. The compressor is covered under warranty, parts and labor for 5 years. I would call for warranty service...Catriver...post back.
Jan 04, 2007 | Amana ABB1927DE Bottom Freezer...
Amana SXD524VW Side by Side Refrigerator Logo
119 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
